Cameras Logo
A
Anonymous Posted on Sep 13, 2013
Error code D048 in konica minolta bizhub c220
5 Related Answers
Anonymous
  • Posted on Nov 19, 2007
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Anonymous
  • 145 Answers
  • Posted on Nov 04, 2008
SOURCE: KONICA MINOLTA
CD231 at power up.
Solution:
CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231.
hope that helps
Anonymous
  • Posted on Nov 10, 2008
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
firecontrol7
Norman Weimar
  • 7035 Answers
  • Posted on Jul 31, 2009
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Anonymous
  • Posted on Dec 30, 2009
SOURCE: Konica Minolta Bizhub c350 error code c-0510
I have this code
C0510 Upper fusing roller abnormally low temp
how can I replace the thermistor in the fuser
Konica Minolta Bizhub C220. It has error code C2557 constant paper jam and faint black and white printout
What is error code c2557 on Konica c220?
Check the toner bottle to ensure that it is feeding toner into the sub hopper unit under the bottle. Sometimes users will insert the bottle incorrectly and not lock it properly in place...the lever on the front of the toner hopper for that bottle is moved down to the left to remove and insert the bottle.
Dec 28, 2010
Error code C2557 - Konica Minolta - Copytechnet
Konica Minolta Bizhub C552. How to reset error code c6752 please?
Trouble Code C-6752 Reset on Konica Minolta C220/C280 ...
CORONA TECHNICAL https://www.coronatechnical.com > 2019/07 > trouble-...
Jul 12, 2019 - This code means is related to CCD. When starting the scanner, verification of reading and writing the predetermined value for image processing ...
1helpful
Konica Minolta bizhub C220 error code C-D010
disable hard discor try to do physicall format in service mode
6helpful
Minolta error c c211
how to can i fix error code c211 in konica minolta bizhub c220
Konica minolta bizhub c220 showing error code c-D048. printer is not working anymore...
hard Drive failure, Re format disk if that fails get a new hard drive.
2answers
Fusing heater trouble konica c220
You need to change the thermistor on the fuser unit.
Error code EA3226 when I try to scan to e mail on Konica Bizhub C220
this error code is not listed in any of the konica c220 books or on the konica minolta service tech internet site
3helpful
3answers
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Top Minolta Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Minolta Camera Expert? Answer questions, earn points and help others
