SOURCE: LG light bulbs
The part number you need is 6912W1Z004B. You can this part at repairclinic.com for about $4 each. I hope this helps you.
SOURCE: bulb for lmvm2055st lg microwave
Can't help with part number as it's not an Australian Model, but refer to http://us.lgservice.com/index_b2c.jsp to help you find a service location!
SOURCE: Black LG microwave oven, fail light bulb inside, I
The oven lamp is accessible when the whole outside cover of the oven is removed. The lamps these days are a special bulb and would be available from a TV repair place or a appliance repair centre.Take the old lamp in with you to pbtain the correct part.
SOURCE: blown bulb for a LG
Just opened mines today .... guide below is almost correct ....when you lift the cover off the bulb is shielded behind a metal box.... theres one screw that connects it to the magnotron .... take off that screw and pull out the plug with the brown and white cables that is connected to the bulb... the bulb is a T170 KEI 240v 25W on mines at least which no one around stocks so will just try and claim under warranty as 2 years labour 6 years parts... bulb has never worked just never got to opening it up ...bulb looked trashed when i took it off... element was all black and in bits rattling inside the microwave ... only use the thing for warming kids milk and sterilising bottles...
SOURCE: LG Microwave oven Tried to
try using a small potato,push it into the base while turning the potato.it may lock onto the base and unscrew it....UNPLUG IT FIRST...
