Question about LG MS-0744Y Microwave Oven
CANT FIND LIGHT TO CHANGE IT - LG MS-0744Y Microwave Oven
Posted by markus whalen on
How to change a light bulb in microwave
Things You'll Need
30-watt incandescent light bulb
Screwdriver
Light
Unplug the Magic Chef microwave from the wall outlet.
Remove the screw from the light cover located on the left side of the underside of the microwave. The light cover is connected to a hinge and will lower, but cannot be removed from the microwave.
Unscrew the light bulb, then screw in the new light bulb. hope this helps
Oct 08, 2016 | Magic Chef Microwave Ovens
How to change light globe in microwave
EVER HEARD OF GOOGLE????
LG LMVM1935 manual
Google
That gets you to the manual.
Page 3 is the table of contents that lists oven light replacement on page 29.
Just maybe, if I teach you this you'll be able to do it yourself next time!
Sep 21, 2016 | LG LMVM1935 Convection/Microwave Oven
I did as it said and removed the cover but I cant find the light fixture so WHERE IS THIS LIGHT BULB ?? I CANT FIND IT !! please help
take the lid off u should have a plastic cover covering the bulb ..see inside were it lights up then look were it is under cover. it will have a black housing or white. also a screw holding it in ..PLEASE MAKE SURE U UNPLUG UNIT B4 TAKING COVER OFF...
Feb 23, 2011 | Sharp Microwave Ovens
DA 399 mEILE RANGE HOOD CANT GET OLD GLOBE OUT TO CHANGE HALOGEN 50 WATT
Remove the grease filters. This will expose the two screws that hold the lamps in. Turn the screws anti clockwise until the lamps drop a little. Twist the lamps gently anticlockwise to release them from the fittings. My instruction manual says reverse the procedure to insert new lamps. Haha. Good luck and be careful.
I had a lot of trouble getting the lamps back in. So much so that I have somehow damaged the fittings or wiring and now have to have a repairman out.... looking at $150 plus just because a light blew!
Feb 01, 2011 | Microwave Ovens
How do you change the interior light. I cant see an access panel either on the outside or within the unit
I think on that model the whole outer casing needs to be removed. These bulbs are designed to last but appearently this one got by them in the inspection department.
Hope this helped you
Dave
Feb 22, 2010 | Neff H5642 Convection / Microwave Oven
Model JVM1790SK 01 Where/how do you change the
This is a pretty bad design, sometimes you can just remove the upper grill and access the light assy. If the panel is to tight to work in to change the light,you get to take the whole micowave down and remove the outer wrapper to change the light bulb. This is also not a standard bulb (part #WB25X10019). You may be able to get one from Lowes or Home Depot actually Sears would be a better bet, otherwise you will need to order one from an appliance parts outlet. Hope this helps and sorry I didn't design the thing I just fix them.
Jan 24, 2010 | GE Advantium 120 Convection/Microwave Oven
Have a Whirlpool RMC275PD microwave. Light bulb
no, no, no,,,its far to dangerous for you to open up the case of your microwave to change a light buld,,,
dont even think of going in there,,,
inside your microwave there are 1000,s of volts stored up in a capacitor if you tuch it you could kill yourself
have you ever seen a police stun gun working,,
it realy hurts you,,,,,
inside your microwave is the stun guns big brother
it dont just stun you,, it could kill you,,,
thats why you dont go inside it ok,,,
the light buld can be changed from inside the case normaly if it cant be, then drop it in the shop for a repair or use it with out a light in it,,
dont try and kill yourself just for a light buld
Oct 31, 2009 | Whirlpool RMC275PD Microwave Oven
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, [email protected]
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
LG MS-0744Y Microwave Oven Logo
267 people viewed this question
Top LG Microwave Ovens Experts
Sheldon Dedek
Randy Schumann
Randy Schumann
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
