20 Most Recent LG LRMM1430 Microwave Oven Questions & Answers
If you go to LG's web site, or indeed most manufacturer's web sites, they have all of the details you require.
Happy browsing and I trust you will find exactly what you require.
LG LRMM1430... | Answered on Oct 30, 2010
take the screws out of the cover take it off can now access the light-check appliance store or hardware for the bulb.
LG LRMM1430... | Answered on Dec 22, 2009
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
LG LRMM1430... | Answered on Dec 12, 2009
I can help solve this fiasco , opening the unit while its running to stop it is not good to do because it will wear the door switches due to the load of power the unit uses while running the switches are not made to cycle the unit.
2nd there is radiation in the unit and around the unit while running so you should not reach in inside the unit immediately when stopped , give it a few seconds. Some commercial microwaves have an un-safe level of radiation 20+ feet away from the unit.
Most likely why they always get the order wrong.
Hope this helps.
Phil
LG LRMM1430... | Answered on Jan 07, 2009
First of all, microwave ovens do not emit ionizing radiation.
The only risk from any leakage is a burn.
Generally, microwave leakage only occurs when the door / door seal is loose or damaged or there has been an improper repair attempt.
You can select a model which lets you turn the beeper on and off by looking for that feature as you shop manufacturer Web sites, or in the store ask the clerk to pull the manual for you to examine, or contact the manufacturer's help center, support center, or FAQ.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. LG / Goldstar owner's manuals can be downloaded here.
If you're interested in other brands, please reply back and let me know. I'll be happy to post contact info.
LG LRMM1430... | Answered on Oct 29, 2008
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
LG LRMM1430... | Answered on Apr 28, 2008
Go for a warranty repair anyway. It may be the magnetron, and the clicking is the big condenser discharging.
https://www.lg.com/ca_en/support/warranty
Microwave Ovens (Over-the-Range):
  • 1 year parts & labour
  • 5 years on the magnetron (part only)
Microwave Ovens (countertop):
  • 1 year replacement warranty
LG Microwave... | Answered on Feb 21, 2021
A Combination microwave has two separate sides to it, a grill with elements and a microwave with a magnetron and associated step-up transformer, capacitors and circuitry.
Check at the rear for a fuse, but you probably need an LG Service Centre. Click Support.
https://www.lg.com/za/microwaves/lg-MP-9485S-microwave-oven
LG Microwave... | Answered on Feb 11, 2021
The fuse is located inside.
LG Microwave... | Answered on Jan 06, 2021
THE HIGH VOLTAGE FUSE IS IN A PLASTIC EXTRUSION NEXT TO THE CAPACITOR AND DIODE.
YOU CAN USE 3 OR 4 STRANDS OF THIN WIRE FROM MULTI STRAND 15A MAINS CABLE. SOLDER IT OVER THE BLOWN FUSE. I HAVE DONE THIS 100'S OF TIMES.
LG Microwave... | Answered on May 18, 2020
It's most likely your door switch. I have the same problem and was told that. I'm not 100% certain, but will take a look at mine and let you know.
LG Microwave... | Answered on Oct 22, 2019
What is it that you are losing ? You can set the power level by using the marked touchpads on the touchpanel, much like setting the volume on a TV. If you do not change the power setting and it is taking a long time to heat things or intermittently fails to, that is usually a sign that the Magnetron has reached its use by date and needs to be replaced. Not always an economical proposition unfortunately as spare parts are often exorbitantly priced.
Before removing the cover of the oven in attempt to carry out any maintenance such as replacing the Oven cavity lamp, make sure the oven is disconnected from the power point ! The voltages in a microwave oven ARE LETHAL !
LG Microwave... | Answered on Oct 18, 2019
LG LRMM1430 Microwave Oven Logo
Popular Tags
22 questions posted
Top LG Microwave Ovens Experts
Sheldon Dedek
acmservice
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
LG Microwave Ovens
  • LG Microwave Ovens
Most Popular Question
light bulb located
  • Microwave Ovens
