TV powers on, Green power light remains green. No picture and no sound. If you press the menu button or try to change channel, TV screen will flash large red blotches but nothing else.
The line output section circuit works as soon as you switch ON the TV, and then come across any short circuit inside the set, and shuts off. That is happening here now. You must check the set, and trace out this shorted or damaged component/s. If you're sound in electronics, download the repair manual to this model set by internet, and carry on. If you're not sound in electronics, contact any service technician. If you wish to get some details about repair work, check the site linked here.
Pull up previous posts or type in the brand name and
model number to of your set, to its search box, and press 'Enter' or
view it in Mosaic / Timeslide option.
SOURCE: My magnavox 37mf321d 37 LCD tv
This is a bad power supply and an easy fix. Their are several electrolytic capacitors on the power supply. If one is bad it will have a bulge on the top. Mine had a bad 2200uF and a bad 1200uF capacitor. About $7 worth of parts at Radio Shack. Radio Shack had the 2200uF but it was axial leads instead of radial. (leads come out of each end instead of one end) but It will still fit. They only had a 1000uf capacitor so I combined that with a 220uF capacitor and wired them in parallel. Make sure you put them in with the correct polarity.
SOURCE: philips TV won't turn on
There is no quick Fixya to this problem, As a repair tech I understand but your PSU power supply unit overheated causing you logic board to give you this flashing red light, I cannot help you 1,500 miles away and would like a good rating for the information though, phillips has so many autherized repair centers that I would call if I where you, this can be fixed for under $100 bucks phillips manavox psu boards are cheap and the labor will dpend on where you live, if this information find helpful to you please rate accordenly thank you and good luck!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: 37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
Unplug and replug it...it should work eventually.
I have the same problem with my 32".
But it eventually goes on when i try it a couple of times (the number of times is completely random...sometimes none, and sometimes like, 3).
SOURCE: Philips lcd tv 42pfl5432d/37 no picture
If you feel you have isolated the problem board, you might check here for a replacement:
Jimmy's Parts
SOURCE: philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
