HP Pavilion dv7-1132nr Notebook PC Logo
Anonymous Posted on Aug 18, 2013
My hp dv6 is almost one mnth old. this afternoon when i booted up, it had 36 795 update operations where 230 where finished in 20min. because I was a bit stressed for time to finish an assignment I didnt want to wait and thought those operation updates could download at another time. unfortunately when i booted again the message 'plug in device boot and press any key" showed. Now I can do nothing and my laptop makes a funny sound. What happened?
pat murray
Level 2:
Sergeant:
  • Expert 293 Answers
  • Posted on Aug 18, 2013
pat  murray
Expert
Level 2:
Sergeant:
Answers
293
Questions
0
Helped
115203
Points
840
When you power on toggle F8 key and then choose go to last good configuration and try that you should never stop or turn off in the middle of updates
5 Related Answers
Anonymous
  • 2004 Answers
  • Posted on Mar 22, 2009
SOURCE: hp dv7 wont boot
Please re your system holding down F11 and the problem will be solved.
Please rate this
Anonymous
  • 527 Answers
  • Posted on May 09, 2009
SOURCE: new hard drive operating system loaded, now cant find hard drive
check the cables it properly connected or not. after start up press F8 key to check the installed hard drive is detected or not. if it is not, check with BIOS settings
Thanks Good Luck
Appreciate to rate as "Fixya"
Anonymous
  • 3278 Answers
  • Posted on Dec 10, 2009
SOURCE: My HP 510 laptop boots Windows XP, but never finishes booting.
Hello.
Either you have a memory issue or operating system problem.
First, try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Testimonial: "Your safe-mode suggestion helped me get past this issue, although I specifically had to do safe mode with networking. Thanks for your suggestion."
engineerayo
OJO Emmanuel Ayodele
  • 169 Answers
  • Posted on Dec 21, 2010
SOURCE: my hp mini is showing
Insert a Bootable Opearating system CD
Reload Your Operating System if Problem persist change your hard disk
Load the Operating System
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Dec 27, 2010
SOURCE: Reboot and select proper boot
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
?????????????????? hope this helps
HP Pavilion DV6-6c35dx Entertainment PC. How to bypass Administrator password on A pavilion dv6-6c35dx entertainment pc
See if the information and videos help you.
HP Pavilion dv6 "Enter administrator password or Power ...
HP Support Community https://h30434.www3.hp.com > td-p
May 14, 2015 - Use that code to go into the BIOS. Disable all passwords that are enabled. If asked for the CURRENT password use that code. If asked for NEW ...
hp pavilion dv6 bypass enter administrator password or power...
Aug 18, 2018
Solved: HP Pavilion DV6 - How to remove BIOS password
May 14, 2018
administrator password or power on password hp pavilion dv6 ...
Jun 13, 2016
I FORGOT MY ADMINISTRATOR PASSWORD - HP Community
Jul 24, 2018
More results from h30434.www3.hp.com Missing: 6c35dx ‎' Show results with: 6c35dx
Top 6 Methods to Unlock HP Laptop If Forgot the Password
MiniTool Software https://www.minitool.com > Partition Disk
Aug 2, 2023 - Method 1: Use the Hidden Administrator Account; Method 2: Use a Password Reset Disk; Method 3: Use A Windows Installation Disk; Method 4: Use HP ...
HP pavilion dv6: admin password - eehelp.com
eehelp.com https://www.eehelp.com > question > hp-pavilion-dv6-...
I forgot the password to an old computer I had cleaned up and now it says "System Disable 58274609" how to do this and the factory restore. I have tried F11 and ...
How to Restore HP Pavilion dv6 to Factory Defaults
AvoidErrors https://www.avoiderrors.com > restore-hp-pavilion-fac...
May 26, 2014 - This tutorial on how to restore HP Pavilion to factory defaults. ... information like Enter your Username and password, time zone, etc.
HP Pavilion Dv6 RESTARTS WHEN SLEEP BUTTON IS CLICKED
Hi
If you know when the last time your computer was working properly, do a system restore at that date. Do another update checking for problems after each one. Don't uppdate hardware drivers from Microsoft. Update from hardware or computer manufacturer (HP, Dell, Toshiba) etc.
Recovery HP DV6
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&docname=c02638587&lang=en&lc=en&product=5210863&
The following link is for your HP DV6, please select your operating system
Once you have selected your operating system, scroll down to (Order Recovery Media)***
Select More Details
and provide your Serial Number to place the order for the recovery
Hp Dv6 pavillion 2040ev blinks 3 times
Your problem is either the memory or the Graphics Card. The DV6000 series was one that had tons of problems with the Nvidia Graphics Card. Oh, since you switched motherboards, did you put the cpu in from the old motherboard and did you apply a fresh coat of Thermal Paste between the Heat Sink and CPU?
4helpful
2answers
HP dv6-2110 won't boot up- 'Hard disk does not exist' I've had my lap top for just over a year. Its been working great! Was fine all sunday morning, then when i came to turn it on to use...
If the battery of the HP laptop is not in a good condition, sometimes booting problems might happen. To remove any static charges accumulated in the battery, you would have to remove the battery and press the Power button for about 25-35 seconds. Then reset the battery. Even after this, if your laptop is not booting up then you could perform the battery calibration and press F8 key to boot in safe mode.
I have a HP Pavilion dv6-3120us Entertainment Notebook. A update came from HP for the BIOS and while installing the update, it will not finish. Its frozen at 100% can you assist?
your options are wait for it to complete. Or power cycle it and hops it froze on downloading, and not during installing.
Manually download the bios update yourself and then flash it manually if it does come back up.
If the computer fails to boot up then you will need to use a recovery bootdisc and then to apply the bios update again manually as opposed to doing it in windows.
My mute button on HP dv6-1030us has stopped responding and is stuck in off. It has been getting dicey but now it's stuck. I have read things about BIOS (which is greek to me) and about synaptics ( I...
what mute? (ah Volume mute key)
no operating system stated, vista, XP , windows 7, or w10 upgraded
what? we cant NOT GUESS THIS. NO ONE CAN< blind.
BIOS is that screen that works, with the hard drive missing,
the minimum intelligence in the system. MIOS is better name.
when you boot and you see words on the screen those first words
like hit F1 for BIOS, or F9 or F10 or Escape.
that is BIOS talking to you,! all PCs do , 1984 to now.
BIOS actually boots the HDD or CDROM or a STICK USB
if you tell BIOS to do that, called configuring BIOS>
end bios 101 (im 69yo)
all we have here is MUTE button as INPUT,
I take it you never downloaded the HP manuals on this?
dv6-1030us
lucky you they are still there. as old as 2011 sys.
get them while still there, ring true ( IT Does for SURE)
RTM,. page 11 on first huge PDF "service GUIDE"
http://support.hp.com/us-en/product/HP-Pavilion-dv6-Entertainment-Notebook-PC-series/3837241/model/3860541/manuals
this #3 is the mute volume button (lamp too)
for this to work only the HP windows disks , used to install
fresh windows, works, MS did not MAKE YOUR MACHINE
HP DID !
Microsoft may not support this, , its a HP device only!
  1. so did you use the wrong disks to install windows.
  2. did you attempt to install drivers here ever? oops.
  3. to make this key work there are 2 paths.
  4. one path is install HP , op sys fresh, (you never stated yours)
  5. you install that and all works like new. end story.
  6. or path 2, vastly harder, using the HP page for your EXACT laptop and exact OS loaded (not MS but HP OS)
  7. you then install all related drivers., the can be 2 or 3 depending on what laptop you have and OS installed. on my HP
  8. the top panel seen below runs off a panel driver from HP.
  9. There are under lying chip drivers that must work first.
  10. so you go to DM , control panel device manager.
  11. and correct all yellow or red marked bad drivers first.
  12. Ill end there, i can not type every permutation of failure here, and the corrective actions step by step.... depends on whats wrong
  13. or if the laptop is INFECTED with VIRUS. and other factors.
  14. like others installing wrong drivers or wrong OS< etc.
mute-wlpfiktypqb3dki104wsq4vq-3-0.jpg why not join the real HP forum and ask there
and not on this silly chat forum.
fixya has zero structures to do that.
on real HP there are libraries of structure and cross linked
to the nth degree,
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
