I was running papers through the automatic feeder and then they started coming out blank and the copier started flashing between the L & #1 and now it will not copy at all?
L1 means the scan carriage (the thing with the bulb and mirrors on it, under the main scan glass) is not moving. It has either been bound up by something or the motor is not running it anymore. On the left side of the machine (facing it) check to make sure the scanner lock has not been turned back on/re-engaged (it should be in the area where the paper comes out and lays down in the exit tray - up under there).
Otherwise... remove the glass and make sure there is nothing binding up the carriage - try move it by hand. make sure the carriage wires are ok. check for any loose cables getting in the way. is everything clean inside? If the carriage is locked up then the drive motor may be the issue - it could have seized. you could disconnect the drive motor and see if the carriage moves freely.
Also you want to make sure the white reference strip under the glass and all the mirrors/bulb are clean.
Hope this will help.
Your copier scaner weakly jump some fuser oil carrage two side
SOURCE: AR-157E blank page when using automatic feeder.
you night check to see if your cable to the copier is connected but this problen iv seen several times not worth fixing the main pcb is usally gone as for as working with the feedder
