Basicaly i havent woren my watch for a couple of weeks and it had stop working i have tried to wound it but nothing is happening. what should i do?
SOURCE: operating instructions for a replica Rolex
I need to know if this watch is an automatic or quartz (battery-operated) watch. For either watch, your crown screws in clockwise- which, by the way, is on the right hand side of your watch, and looks like a miniature doorknob. Unscrew it COUNTERCLOCKWISE, then, if your watch has a date on the dial (face of watch), your crown will pull out in two different positions. The first position is for your day/date. Forward will either do the day or date and backwards will do the other. DO NOT SET YOUR WATCH BETWEEN 10 O'CLOCK AND 2 O'CLOCK, because it can ruin your watch. The second position (pull out completely) is for setting the time. Go around until the day and date changes so you're sure that you're on a.m. or p.m. and then set accordingly. Push the stem all the way back in - this is your winding mode if you have an automatic. Wind 50 times before use, or else it won't run correctly. Now, push the stem back in (it's spring-loaded), and turn it counterclockwise to seat the tap, then clockwise until it's completely screwed in.
SOURCE: I can not open rolex bracelet
Sometimes Rolex bracelet clasps are very tight and this only shows the quality of the watch.
Don't be afraid to pull the clasp hard enough to open it- nothing will brake as Rolex is designed for quite hard use.
If you can't do it by hand, try to use flat butter knife end as a lever.
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
unscrew the winding pin until it opens to the first position. (this position is for self winding. approx 30 turns clockwise will fully wind the watch)pull pin to the next position. this sets the date if it is a quickset. 1985 to present. again turn clockwise to the desired date is present. pull the pin to the final position and this will set the time turning clockwise as well. hope this helps.
SOURCE: unable to manually change date on my Rolex Oyster
Usually to change the date you need to have the crown pulled out to a position that is between the "closed" position and the position where it will move the minute/second hands.
SOURCE: ROLEX OYSTER PREPETUAL HOW DO I ADJUST THE TIME?
Unscrew the crown, pull out the crown fully to the second position. and rotate the crown counter clockwise or clockwise. Push the crown back in and screw down the crown.
I have the same problem with Perpetual Date. I used to wound it b/c it only rn about 2 or 3 days at the time and now there's no tension when I wind it.
