20 Most Recent Rolex Oyster Perpetual Submariner Date Wrist Watch Questions & Answers
For Casio watches, the number on the back is the module number. For ROLEX I have no idea. Never saw one in my life.
Rolex Oyster... | Answered on Aug 31, 2014
There are tiny pins either side of the wrist band next to the clasp. Remove these pins and you can take out up to two links (and a half link on some models.)
A jeweller could do it, needs a special tool to tap them out and put them back
Rolex Oyster... | Answered on Mar 06, 2014
If it is a true Rolex they require a special wrench that grips the tiny serrations around the base of the back. You will need to take it to a watch repairman, the tool is very costly.
Rolex Oyster... | Answered on Oct 08, 2012
Hello
Get into this link. You will get all the details from here.
www.youtube.com/watch?v=1QqN5QBHdB4
Rolex Oyster... | Answered on Jan 30, 2012
Tip
How to manage your SUBMARINER's size to fit your wrist
Take of your ROLEX, look on the inside of the bracelet. Near the area where you have the crown, there is a miniature circle, push with your thumb on it with strenght, you will hear a click . You pull your bracelet , it will open, then you look on the sides of the bracelet, and you insert a needle into the little screws on both sides, and then you choose the size you wish for your watch , and then put the circle back and close everything again.
on Oct 10, 2010 | Rolex Oyster Perpetual Submariner...
Thank you for contacting FixYa.
  • Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different.
  • 2
    Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step.
  • 3
    Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar.
    For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
  • 4
    Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase.
  • The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues.
    Hope this helps. Jewel
    Rolex Oyster... | Answered on Oct 08, 2010
    Its not unheard of depending on the age of the watch (you say you purchased it 16 months ago but it could be a 15 year old watch.) If it was a new Rolex watch you have a 5 year warranty, so it should cost you nothing. If it was a pre-owned Rolex you should have received a warranty from your jeweler, most of those are 2 years. If this is a watch with value, and one you will either hand down or at some point resell then sending an older watch to Rolex is the proper direction - save all the repair documents, with the original receipt and the box. A Rolex Explorer II in good condition in US is about $5k, so $380 for a repair, though high, is worth it. I would recommend that if you do send it to Rolex for this repair and it is an older watch have it serviced too. The watch is returned to you in perfect condition with fill documentation.
    Lastly, you need not to send it to Rolex at all. Any good watchmaker/repair jeweler can do this for less than $380US.
    Rolex Watches | Answered on Jun 08, 2020
    https://www.youtube.com/watch?v=RzQcj1ulIkQ
    "Five hundred dollars for a '93 Rolex Daytona," he says, "I'll do it!" That same watch is valued at around $16,000-$19,000 now, depending on its condition.Jul 30, 2012 https://www.exquisitejewelersmiami.com/blogs/rolex-daytona-watches/6351872-the-rolex-daytona
    Rolex Daytona Size and WeightDaytona watches are large and typically measure 40mm across. Weight for the Rolex Daytona varies based on the material used. For instance, it ranges from 148 grams for the stainless steel model, to 195 grams for the white gold, to 283 grams for a platinum Rolex Daytona.
    https://northscottsdaleloan.com/watch-reviews/rolex-daytona/
    Rolex Watches | Answered on Apr 29, 2020
    Doubtful. if you bought it cheaply. A jeweller will be able to tell. There are many authentic looking knockoffs. :-)
    Rolex Watches | Answered on Jul 17, 2019
    WTF!
    Are you brain challenged? What is the question?
    Rolex Watches | Answered on Jun 07, 2019
    Rolex Oyster Perpetual Submariner Date Wrist Watch Logo
    Popular Tags
    16 questions posted
    Top Rolex Watches Experts
    Bruce Robin
    Janelle Schoonover
    Janelle Schoonover
    Are you a Rolex Watch Expert? Answer questions, earn points and help others
    View Most Popular
    Rolex Watches
    • Rolex Watches
    Most Popular Question
    number 381 back watch mean
    • Watches
