Question about Rolex Oyster Perpetual Datejust 116200BLSJ Watch for Men
When I turn my Rolex perpetual date just watch upside down it stops moving. Only works if facing up. Please help.
Posted by Nancy wilkie on
  • Nancy wilkie Sep 24, 2012
    It winds properly. Just stops when put face down.
  • Rolex Master
  • 18,429 Answers
The shaft on one side of the balance wheel as broken and needs to go to jewelers for repair.
Posted on Sep 24, 2012
1 Related Answer
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Mar 07, 2009
How to set the time and date to my rolex, and if under number 6 when you remove bracelet i don't have number that means is a fake?
That number does correspond with a genuine Rolex. Stop Ina watch repair store where they actually do the work. I have not seen a knock off with a serial numbers or model number stamped between the case lugs.
Hope this helps.
Nov 11, 2014 | Rolex Oyster Perpetual Lady Datejust...
The date and day have stopped working on my replica rolex daydate i have adjusted the pin several times but it is still not moving?
Your calendar wheel is damaged. Unfortunately, it is illegal to own or work on a Rolex replica / fake Rolex as it is a trademark violation. I would suggest purchasing a genuine Rolex as a replacement, as there are generally no identifiable movements, and therefore no identifiable replacement parts for the movement in your timepiece.
Be aware, however, that all automatic and mechanical watches, such as Rolex, must be services regularly, every 3-5 years, for them to last and work properly. Thanks for the rating!
Dec 16, 2012 | Rolex Oyster Perpetual DayDate 118239BKSP...
Cloudy face of my rolex oyster perpetual date, womens
Dont swim with it anymore - Its time for a service.
Take it to any Rolex re-seller that offers repair or to any good timepiece service center. If its a vintage piece i would recommend sending it to Rolex, paying the extra cost to receive the watch with full Rolex repair documents and service history. The Rolex web site has information on this. Also this company does a fine job on Rolex repair. https://www.bobswatches.com/rolex-repair-service
Jul 16, 2012 | Rolex Watches
Can you please tell me how to set my Rolex Oyster Perpetual Datejust? Day light savings toime ends this evening and the watch needs to be set back 1 hour.
Unscrew the crown and then pull the crown out to the second click and turn. When done push the crown back in and screw the crown back down.
It is very important to screw the crown back down. If this is not done the watch is NOT water resistant.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Oct 31, 2009 | Rolex Datejust SS
Oyster Perpetual Day Date keeps stopping
That does sound like a peculiar problem. Without looking at it it's difficult to say. It possible the date change - stopping situation is co-incidental. All mechanical watches, particularly high quality one such as this should be serviced every two to three years to ensure optimal performance and preserve their value. I recommend you take it to a qualified repairer. Good luck.
Jul 28, 2009 | Watches
How do i wind and set my Rolex Oyster Perpetual watch
After all settings being done, always screw the crown back down as it protects the watch from water and moisture.
Apr 04, 2009 | Watches
I need an owner's manual for a Rolex Oyster Perpetual Day-Date. Any idea where I can locate one?
Mar 31, 2009 | Rolex Day-Date President 118238 Wristwatch
How to adjust day date on older rolex perpetual day date watch
Mar 06, 2009 | Rolex Datejust SS
Rolex Oyster Perpetual Datejust 116200BLSJ Watch for Men Logo
694 people viewed this question
Top Rolex Watches Experts
Bruce Robin
Janelle Schoonover
Janelle Schoonover
Are you a Rolex Watch Expert? Answer questions, earn points and help others
