Hello. I have no heat, light or fan working on the main oven. The small oven and the hob all work fine.
SOURCE: SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
SOURCE: Smeg SNZ91MFX1 Fan heating not working
It could be that the element around the fan (which is obscured by metal plate) has gone. Remove the metal plate in front of the fan, and test with a multimeter to see if a current gets through it...
Easy to order and replace yourself
SOURCE: no heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
SOURCE: smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
