SOURCE: Well my Garmin nuvi 1300 was working fine
it sound like someone has "unticked" maps go to settings then maps and map info and look for the screen that says city navigator, and tick box that should work unless someone has attached to pc and wiped maps
SOURCE: garmin 1300 stuck on maps loading frozen
I had the same problem with a 1300 unit and a car charger. After holding power button for 10 seconds it would begin to start, but get stuck while saying "Loading Maps." and then it would shut off again.
I fixed it by plugging the unit into a computer USB port. It then did it's PC connection startup as usual, which leaves a connection icon on the screen. I gave it a minute and then unplugged it from the PC. It then restarted and booted up properly.
Hope this helps.
SOURCE: 1300 nuvi screen comes up loading maps and stops...
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is
acting erratically is symptomatic of having corrupt
firmware.
To
correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck,
then updating your Nuvi firmware.
Follow
these three steps to take to get
your Garmin Nuvi 1300
running like new:
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
SOURCE: my garmin nuvi 1300 shuts
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
For service/repair of a device due to the three symptoms listed above please select "No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
SOURCE: My garmin nuvi 1300 keeps
There's a solution to your problem at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
The article deals with all possible reasons for there being no map data available but if your satnav is working other than that it may be just that the map is not selected. If you can get into the menus first try selecting the map by
pressing TOOLS
then SETTINGS or LOCALE on models that don't have a settings menu
Press MAP and then at the bottom of the screen press MAP INFO
Your map name should be there and a box with a tick beside the name.
If the box is not ticked press on the map name and it will cause the tick to appear. This might solve the problem. If not the map is probably locked. You'll find details of how to unlock the map at the above link.
