I checked the power cord it is good. The tower will simply not start up, a lil light flashes on the right of the tower but i don't know what that means. Any ideas would be much appreciated, thank you
- Tommy
Yonkers, NY
It sounds as if your power supply is having issues, I would recommend replacing it. If your good with computers, you can test the power supply:
1. Open the computer tower.
2. Find the main plug which runs from the power supply to the motherboard.
3. There should be 16 wires.
4. Find the green wire, short it to the black wire with a paper clip.
5. If the computer seems to turn on, its your motherboard having issues and you will probably need a new computer. If it does not turn on, your power supply has failed, and you need to replace it.
I hope this helps!
Can anyone please explain more detail about how to "short it to the black wire with a paper clip". Does this mean touching a paper clip to those two points so electricity can flow between them? Will I get a shock if I hold the paper clip in my hand as I do this (sorry if that's an ignorant question, I know nothing about electrical power/supply).
