Sounds like its coming from around the driver side front tire, what could it be??? just replaced the timing belt, distributer, distributer cap, rotor, and ignition coil. i also noticed it doesn't accelerate as well as it did before all the work. please help
The Timing Belt could be a tooth or 2 off or the distributor could be off in angle, you probably will have to have the timing set with a timing light, that will cause pinging and lack of power. most times its juts needing the timing set correctly, it could be just a few degrees out.
Sounds like u got some pinging, make sure ur timeing is installed correctly , the timeing belt , balancer belt and oil pump drive gear all must be aligned properly when installing the new timeing and balancer shaft belt. if the balancer shaft is not lined up correctly, you may experience a power loss and engine vibration.
