Microsoft Windows XP Professional Logo
Posted on Mar 28, 2009
PROBLEM WITH EXCEL
When i opening my excel set the error massage showing it,Excel exprienced a serious error the last time the add-in c:\mso1033.ad was opened.would you like to disable the add-in?to reactivate this add-in,click about micrsoft office excel on the help menu, and click disableed this items. i tried get in excel set but i could not access in excel set.
Jeffrey Cohen
Level 1:
  • Contributor 24 Answers
  • Posted on Mar 28, 2009
Jeffrey Cohen
Contributor
Level 1:
Answers
24
Questions
0
Helped
5500
Points
44
  1. Click the Microsoft Office Button PROBLEM WITH EXCEL - default.aspx?assetid=za100771021033, click Excel Options, and then click Add-Ins.
    1. View the add-ins and application extensions that are categorized as follows:
    2. Active Application Add-ins Lists the extensions that are registered and currently running in your Office program.
    • Inactive Application Add-ins Lists the add-ins that are present on your computer but are not currently loaded. For example, smart tags or XML Schemas are active only when the document that references them is open. Another example is the COM add-ins that are listed in the COM Add-ins dialog box. If the check box for a COM add-in is selected, the add-in is active. If the check box for a COM add-in is cleared, the add-in is inactive. To learn how to open the COM Add-in dialog box, see the section called Turn off or manage the installed add-ins.
    • Document Related Add-ins Lists template files that are referenced by currently open documents.
    • Disabled Application Add-ins Lists add-ins that were automatically disabled because they are causing Office programs to crash.
  • Add Your Answer
    2helpful
    4answers
    Cannot open file. Error message reads: Excel cannot open
    Use Excel Repair Toolbox is efficient corrupt XLSX file repair software, suitable for all data recovery activities, applied to Microsoft Excel documents.
    For more: https://www.xlsxrepairtoolbox.com/
    When i open Excel or world file then show error mmessage-Not enough memory to run excel or world
    Restart computer.
    Save changes more frequently in Word/Excel.
    Add more memory. (www.crucial.com)
    2answers
    Delete blank rows in excel using visual basic
    have you tried to read in one file and write back in excel format only the non-blank rows?
    1helpful
    5answers
    Excel file not opening
    Try:
    XLSX Repair Kit. The latest corrupt XLSX file repair software featuring a powerful data recovery core and a convenient step-by-step wizard for extra convenience.
    For more information: http://www.xlsx.repair/
    If doesn't help look for the answer here:http://www.filerepairforum.com/forum/microsoft/microsoft-aa/excel/653-i-get-a-message-that-the-file-is-damaged-or-corrupted
    28helpful
    5answers
    Word & Excel won't open files when doubleclicked in Windows Explorer
    Excel may have "Ignore other applications" selected. See THIS Microsoft Knowledgebase Article.
    Try going to Excel Options; Advanced tab; and under the 'General' heading: uncheck the box that says: Ignore other Applications that use Dynamic Data Exchange (DDE).
    2answers
    Can't reopen circular reference file in excel
    1. Click the Microsoft Office Button , click Excel Options, and then click the Formulas category.
    2. In the Calculation options section, select the Enable iterative calculation check box.
    3. To set the maximum number of times that Excel will recalculate, type the number of iterations in the Maximum Iterations box. The higher the number of iterations, the more time that Excel needs to calculate a worksheet.
    4. To set the maximum amount of change you will accept between calculation results, type the amount in the Maximum Change box. The smaller the number, the more accurate the result and the more time that Excel needs to calculate a worksheet.
    1helpful
    2answers
    Excel password is protected....... but not i don't know that password,,,,,,, so password are remove if i see that password
    Excel Password Remover 2008
    Instructions
    FAQ
    Disclaimer
    Excel Password Remover PRO
    Recommended links:
    Password recovery software (Word, Excel, Outlook, Exchange, Visual Basic modules, Access, Winzip, Lotus 1-2-3, Lotus Organizer, Lotus Wordpro, Backup, Project, FileMaker, Schedule+, Money, Paradox, Act!, Mail, Windows NT)
    Instant password recovery (Instant online recovery service for password protected MS Word and Excel files. Free online preview of encrypted file content. )
    Visual Basic Password (Instant recovery of VBA-passwords in Office programs)
    Excel add-in decompiler (Converts Excel add-ins into normal workbooks)
    Have you ever forgotten your Excel workbook or sheet password?
    Here you can download a FREE Excel add-in that removes/cracks sheet and workbook password protection in Excel®.
    NB! This program can't remove file protection, i.e. if you are unable to open the file, this program won't help you. You could try Excel Key to remove file protection. If you need to crack the VBA-password try this one.
    This Excel add-in (password.xla) works fine in Excel 5.0 and above (including Excel 2000, XP and 2003).
    This program will remove passwords of any length, also passwords containing special characters.
    Download here: password
    2answers
    Loading Excel and Word
    I would try uninstalling Excel and Word and reinstalling. Something seems corrupted.
    Top Microsoft Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    k24674
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
