Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
Posted on Mar 25, 2009
Problem with AV 4 input only.
I have a PS3 that I've been playing my blu ray movies on, only on the AV4 input. I have recently moved and now the AV4 input has a green screen when I plug my PS3 into it. Only the CVI and the AV4 are HD capable, but on my set, AV4 has a much cleaner picture (1080i) than the CVI input. Can anyone tell me what the problem may be? Thanks in advance.
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Apr 10, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
1664
Points
7
Check to make sure your settings on your PS3 are set to the RED BLUE GREEN (component) input.
3answers
Ps3 slim blue ray won't play can't find settings
Will it play anything? The laser eye may need to be cleaned. Sometimes the drive will play DVDs but not games, or games and bluray movies, but not DVDs .... in that situation, the bluray laser may need to be replaced
2answers
My ps3 plays games but will not play blu ray movie
You can try clear your movie data from the discs you\'ve played (according to Fox that\'s sometimes the culprit when a disc won\'t even load): restart your PS3 and go to the video menu and scroll up to the BluRay Data section. Go into it and check that it has saved some info for your movies. Now deleted all the data in this folder except the shared data crap, and hopefully your movies start perfectly!!
If that fails try the following:
In the XMB(menus) go to Settings ---> BD/DVD Settings ---> BD 1080p 24 Hz Output (HDMI). Turn that off. This has also been known to work.
My ps3 slim won't play games and blue ray disk but I can still play eve movies on it, please help want to try an fix if before nhl 12 hits the stores.
Hi, It sounds like there's an error with the laser that reads blu ray media as PS3 games and blu ray movies are both stored on blu ray disks which is read by a different type of laser then a dvd is read by. There's nothing you could do to fix that on your own, the only fix I've heard of is sending it in to Sony.
3answers
My ps3 will play ps3 games but not dvds. it loads the dvd then turns black. Any suggestions?
You can follow below steps to play DVDs on PS3.
Step 1: Insert Blu-ray disc into PS3's Blu-ray drive. Playing Blu-ray disc movie works exactly the same way as entering a game, except you need to head into the Video Tab in your PS3's home menu, rather than the Game Tab. Highlight the Blu-Ray and press X to start it immediately.
Step 2: Now the Blu-ray disc will load like a traditional DVD. Use your controller to access the menu, and use the D-Pad to select your option and press X to enter. When the media is playing, you can press triangle to open a mini-menu that will give you access to options such as subtitles, audio channels and volume. You can also access the main menu, using the arrow keys to navigate. Press triangle again to close this menu.
However, if you can't do it successfully, try to convert DVD to regular video and transfer to PS3.
Step 1: Download and install Leawo Blu-ray to PS3 Converter, and then launch it.
Step 2: Get source Blu-ray movies ready. Insert Blu-ray disc to the Blu-ray drive, or get source Blu-ray folders ready for loading and converting.
Step 3: Load Blu-ray sources
Click "Add Blu-ray/DVD" button on the program interface. This Blu-ray to PS3 converter would then guide you to browse source Blu-ray movies for loading.
Note: After loading source Blu-ray movies, you could select subtitles and audio tracks, play source Blu-ray movies, edit Blu-ray movies, snap screenshots, etc.
Step 4: Do output settings
Next to the "Add Blu-ray/DVD" button, click the dropdown box and select "Change". You will then arrive at the Profile setting panel to select output format from "Format" group or "Device" group. Select "MP4? from "Format" or directly choose "PS3? from "Device > Sony".
Optional settings: After you've set the output format, click the same dorp-down box and click "Edit" option and then you could adjust video and audio parameters of selected profile, including: video codec, audio codec, bit rate, aspect ratio, frame rate, channel, etc.
Step 5: Start converting Blu-ray to PS3
Back to the main program interface, click the green "Convert" button. You could then set an output directory on the right popup sidebar. After setting output dirctory, click the below convert button to let this Blu-ray to PS3 Ripper instantly start converting Blu-ray to PS3 videos.
Note: Internet connection is required during the whole conversion.
After you convert Blu-ray to PS3 friendlier videos, you can transfer the videos to PS3 and then start to play Blu-ray on PS3 in a indirect way. For details, you can read the extension part.
For more details, check: Direct and Indirect Ways to Play Blu-Ray on PS3
4answers
PS3 will play games but not movies
Well if the regular dvd's dont work.. I would recommend you to buy Blu-Ray movies instead.. PS3 is the best known blu-ray player. buy at least one blu-ray movie and try that.
3helpful
4answers
My new 3.15 ps3 won't play blu-ray but will play everything else no problem. no problems to play games or to play normal dvd's. When playing a blu-ray the UNIVERSAL part at the start of the movie plays...
f the Blu-ray Disc does not support 1080p 24Hz video mode, the video output may not display properly.
If a Blu-ray Disc movie is not loading properly or is freezing on a title screen, this may be caused by the PLAYSTATION 3 attempting to download BD-Live content from congested movie studio servers. If you experience this issue, you may choose to temporarily bypass the BD-Live content until the congestion at the movie studio servers has cleared.
Go to Settings icon (Settings) > Video Settings icon (Video Settings) > [BD Internet Connection], select "Confirm". Then reload the Blu-ray movie and the PLAYSTATION 3 will prompt you if you wish to allow the disc to access BD-Live content. Choose to not access BD-Live content to see if the movie will now load.
For some reason you seem to think this is a PS3 problem. Why do you think this is a PS3 problem? If you can play PS3 games, then I will say it is not a PS3 problem, as all PS3 games are on Blu-ray, and if you were having problems playing PS3 games, then that could account for the movie not working.
Since only the movie isn't working, I am going to say you have a defective Blu-ray disc. Did you just buy this movie, or have you viewed it before using the PS3? If you have never viewed it on the PS3, then the problem lies in the disc, and you need to take it back and have it exchanged.
If you have played the disc in the PS3 before (the PS3 you are having a problem with, not a different PS3 or Blu-ray player), or you still think it is a PS3 problem, then use the "Disc Troubleshooting" support page. Normally, if a Blu-ray movie will not play, it won't play at all, and it is because the Blu-ray laser has gone out. It sounds to me that the disc is bad, but this is only going on the information you have supplied.
Here is the Disc Troubleshooting support page mentioned above:http://playstation.custhelp.com/app/answ…
**EDIT**
Sorry, I just noticed you gave a UK link. Here is the support page for the UK. You will have to do a search on the site to find the Disc Troubleshooting page for your region.http://uk.playstation.com/support/
**EDIT**
Okay, here is your Disc Troubleshooting page for the UK:http://faq.en.playstation.com/cgi-bin/sc…
3answers
Ps3 wont play blu-ray but will play dvd
Maybe your PS3 Blu-ray playback partition has been damaged. But you can convert the Blu-ray to regular video and transfer to PS3 for playback.
Leawo Blu-ray Ripper is an easy-to-use Blu-ray to PS3 converting tool to help you rip and convert Blu-ray file to PS3 videos in only a few simple clicks. The below step-by-step guide would tell you the details on how to rip and convert Blu-ray to PS3 videos with Leawo Blu-ray to PS3 Converter.
Guide on how to convert Blu-ray to PS3 videos:
After the conversion is completed, now we should transer Blu-ray movie now in PS3 fridlier video format to PS3 for playing Blu-ray on PS3. Follow the steps below to do so.
Here is a simple step-by-step guide for transferring to or watching video files on your PS3 using a USB flash drive or an external hard drive.
Step 1: Plug a USB flash drive or an external hard drive into your computer and copy over the converted video files that you want to watch on your PS3.
Step 2: After the copying process is done, pull out the USB flash drive or the external hard drive from your computer and then plug it into one of the USB ports on the PS3.
Step 3: Navigate to "Video" on the PS3 XMB menu and find your device, hit triangle to view all contents and select the file you want and either copy it to the PS3 hard drive or just play it directly from the connected device.
By following the guidance above, you can achieve your goal of more safely and conveniently playing Blu-ray on PS3 or watching Blu-ray on PS3 for protecting either PS3 Blu-ray drive or your precious Blu-ray discs from being scratched.
3answers
Ps3 wont play movies
My PS3 met the same issue. But I have tried to convert the Blu-ray to HD video and transferred to PS3 for playback. Maybe you can do this like me.
2answers
Ps3
try setting the console back to factory settings, i had the oposite problem, would play games but not movies. will it play blu-ray movies or regular? if it doesnt play blu-rays, your disc reader may have gone bad.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
