D1210 audiovox won't light . Will come on and when you hold a flashlight to the screen you can see a faint pix. i think the lamp behind the screen is bad. Can anyone help. thanks [email protected]
Are you still under warranty with this product? Have you tried to reset the DVD Player to the factory settings. You can do this by opening up the menu and on the main page highlight preferences and press enter.Now go to the default setting and highlight it and press enter. This will reset the DVD player to the original settings.If this doe not solve your problem you can call Audiovox customer support at this telephone number. 1-800-645-4994. Give them the model number of you DVD player and tell them the problems you are having. They will be able to tell you how to get the unit serviced. I hope this information helps you with your problem.
"Lock" systems do not prevent the screen from lighting up. Your problem is either a failed lcd inverter or a failed lcd. Try holding a flashlight onto the lcd screen to see if anything is( faintly) visible. If you can see very faint images, the lcd inverter is defective. If you see absolutely nothing, the lcd has failed.
That will be the screen driver chip faulty or even the luminance set too high. Try turning the brightness down and if there's a dark picture it's the chip, if not maybe even the flexi strip from the base to screen.
it could be a backlight problem. Try this, dim the lights in the room, turn the set on. Take a bright flashlight and shine it on the screen. If you see a faint image on the panel, you have a backlight fault.
You likely have a LCD set there which may likely use a back light inside to light the image, get the room as dark as you can and with a flashlight illuminate the screen from a angle, with set on if you can see the faint image on the screen of the program you have a Backlight issue'
1. Voltage not there or not being switched on for backlight.
2. Actual back light bad.
If the image can be seen with a flashlight one of the above is the issue and your "picture will appear very faintly" also suggests this.
This model has a set of two backlight lamps, and it is practically impossible that both lamps go faulty at the same time.
When the backlight lap in an LCD TV goes off in this way, the faulty part is always the backlight inverter, that is the high voltage board powering the lamp.
In your case you have to get the TV inverter booard replaced.
If you are still under warranty try calling audiovox customer support at this telephone number 1-800-645-4994. Give them the model number of you dvd player and tell them the problem you are having with the dark screen. If you are not under warranty, You can still call them and ask them where to get service for bad power inverter or a bad back light problem. If they cannot help you you can go to this website http://www.lcdparts.net/Default.aspx They do all kinds of LCD repairs and also have a technical help telephone number. 1-877-870-0581. Give them a call and tell them the name of your dvd player and the model number and see if they can help you get repair service for it. I hope this information will help you with your problem.
Audiovox code hack For DVD player D1210 1. power on
2. SETUP
3. in setup digit 9653
4. go to new menu VERSION
5. in region use UP/DOWN to change region
6. power off and power on
7. Enjoy!!!
You can try to reset the DVD player to factory setting. Go to the set up main page. Highlight preferences and press enter. Go to the defaults setting and press enter. This will reset the DVD player to the original factory settings. If this does not solve you problem you can call the Audiovox customer support telephone number. 1-800-645-4994 Give them the model number of your DVD player and tell them the problem you are having with it. They will be able to tell you how you can obtain service for your problem. I hope this information helps you with your problem.
We bought this player almost 5 years ago, and have the same problem. When we called audiovox at the time they told us that it was because some of the dvd mnufacturers had changed the format/technology in which they recorded the dvd programs. The biggest problem was with the Disney dvd's. Also, that they did not have any software upgrades at that time to upgrade the player. We used it for a while with the hit and miss movies that it would play, and then finally shelved it and bought a minivan with a preinstalled dvd player. Very rarely use the audiovox now. I am surprised; however, that after 5 years they would still have the same problem and have still not yet upgraded the software in this player. Good luck.
