Audiovox Jensen JTFT-250 2.5 in. Handheld Television Logo
Posted on Feb 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jensen VR187 monitor will not go back in or come on.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2375
Points
Unit will not comeout of storage position.
help
Anonymous
Level 1:
New Friend:
  • Posted on May 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2375
Points
Obviously power on and monitor in the center position. Not tilt back and forward; but, the left-right manual adjustment. Put in in the center position. Hold return button down for couple seconds.
Doesn't retract.
Use the reset button that is at 5 o;clock. Hold in for 1 second the release.
I recomend that you run the unit through the in/out cycle and tilt back/forward several times. Reset again as need.
Still doesn't work? I can't help.
  • Anonymous May 23, 2010
    Doesn't retract.
    Use the reset button that is at 5 o;clock OF THE VOLUME KNOB. Hold in for 1 second the release.
    OBVIOUSLY power on and monitor in the center position. Not tilt back and forward; but, the left-right manual adjustment. Put in in the center position. Hold return button down for couple seconds.
    Doesn't retract.
    Use the reset button that is at 5 o'clock OF THE VOLUME KNOB. Hold in for 1 second the release.
Blake
Level 2:
  • Expert 136 Answers
  • Posted on Mar 14, 2010
Blake
Expert
Level 2:
Answers
136
Questions
Helped
35601
Points
159
Make sure you do not have it in Video Mode or Cable mode. Check the menu and see if you have the brightness/contrast/color and see where they are. if they are below 0 then you will have black screen. also, your state might have changed to digital programming so you will only get Canada stations only.
JENSEN VR187 MONITOR KEEPS SAYING NO SIGNAL I have sound, but monitor says “no signal “
The graphics card supplying the signal could be bad, a pin could have been bent over when you plugged in the vga cord (if a vga display).
If a pin is bent, be careful bending it back; it can break off easily. Grab with needle-nose pliers or tweezers, and slowly bend. Don't over-bend.
Wanted a remote for the Jensen VR187
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electro-medical.blogspot.com/
Is the jensen jrv212t able to get sirius
YES! But you will first have to get a modulater. They sell them at best buy for about $50 the last time I checked. You have to get one made for a Jensen. They are easy to install, but you do have to pull the head unit from the dash.
How do I set the clock on a jensen vr187 cd/ car radio
1. If the radio / i-pod is on- turn it off.
2. Hit the 'mode' button until the time flashes (it should be 3 times).
3. Use the Tun +/- button to change the hour.
4. Use the Volume +/- to change the minutes.
5. Click through the rest of the options to change between setting the alarm, how to be woken up (chime, ipod, etc), 12/24 hour format, year, and date.
Tv monitor
there is a problem inside; take it back and get another one or call jensen and you might have to send it to them for replacement.
Our new motorhome came with a sirius ready Jensen vr187 radio-how do we hook up to Sirius, and does it need an antenna, or is that part of ''sirius ready''?
Sirius Ready means that there is another piece the company makes that is for sale seperately from the reciever. you need to get the whole sirius system and it will just plug in and play through your existing setup.
5helpful
Jensen VR187 radio/backup camera observation monitor won't work
In the manual look on page 10 step 10. You have to use a ball point pen and straightened paper clip (better) to reset the unit. There is a small hole at the lower left of the Volume knob. That's where you insert the paper clip.
Monitor wont come out
I have the exact same problem on mine. If yours is like mine, It clicks a little when it tries to open and close. If that is the case, The gears that open the dvd player might be stripped or just need to be adjusted.
Top Audiovox Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
