Audiovox AVP7000 VCR Logo
Question about Audiovox AVP7000 VCR
Dew light is on vcr and will not play tape what can I do
Posted by hayesjtms on
Anonymous
    New Friend:
I've got a 12v video and suddenly i've got a DEW red-light on and the vcr won't play either, someone's got to know? Please write w/a solution please. [email protected]
Posted on Mar 03, 2012
Anonymous
  • 72 Answers
Take a hair dryer on low setting and try to blow warm air into the vcr to warm it up until light goes out
Posted on Jun 11, 2009
2 Related Answers
Anonymous
  • 579 Answers
SOURCE: AUDIOVOX VCR SER#S9AA02677 MOD#AVP7000
That is 'dew' as in wet. Do you have it in a warm, dry location? This time of year they can attract condensation if the VCR is in a cold place.
Hope Ya Fix it!
Posted on Jan 06, 2008
autolatry
austin ortega
  • 115 Answers
SOURCE: theres something on the vcr yhat says DWE OR DEW
the DEW light is a warning light. it indicates moisture on the tape. so make sure the tape is dry and in a ventelated area.
Posted on Mar 08, 2011
Where is the dew sensor located inside the Samadhi tv/vice tv
www.fixya.com > Forum > Tags
Jul 13, 2009 - TV is playing Also,the letters D E W are on the screen. Can you Help me? there is what is called a "dew sensor" in a lot of vcr's that keep you from playing a tape ... 9'' memorex tv/vcr player shows ''DEW'' on screen ...
Apr 3, 2009
SOLVED: "DEW" is on screen and VCR not working
Jun 30, 2007
More results from www.fixya.com
Theres something on the vcr yhat says DWE OR DEW and theres a red light flashing beside it when thats flashing it wont allow the movie to play what does that mean
2answers
Tape won't play
Hi hwgs,
The "DEW" warning appears if a VHS player or recorder has built up humidity. This, much like dew found on the grass on a cool morning, is the result of condensation building up, ususally after a temperature change. Once the moisture has evaporated the unit should work properly.
Be sure to keep your TV away from sources of humidity, such as a window or a bathroom/kitchen door. Also, make sure it is in a climate-controlled room away from drafts so the temperature does not change rapidly.
Thank you,
Jason,
Go Ahead. Use Us.
Hello mountain8,
It sounds like the dew sensor might be bad and giving a false reading. If you have the ability to you could disconnect the dew sensor to see if it is the problem.
I hope this helps,
Thank you
Shuttle83
Hope Ya Fix it!
Code F13
It's sounds like the vcr's tape mechinisum is malfunctioning to me. Try unpluging it for a while. It will correct itself. Or it might have
dew sensors if the room is too cold the vcr wont work until the dew it gone off the heads. If it don't have dew sensors
and plays the tape with dew on it might eat the tape.
also if a timer is overlaping or is set to come on right now it might do this.
3helpful
Sansui TV/VCR 13" color
there is what is called a "dew sensor" in a lot of vcr's that keep you from playing a tape if it senses moisture in the unit because a tape will stick to the video head and get all bunged up. sometimes they go bad and will keep you from playing a tape even when there is no moisture present. if your are electronically inclined you can take the back off and locate the dew sensor, then disconnect it. the constant whirring noise is the unit's way of trying to dry off the video head cylinder. the dew sensor, which is usally located behind the video head, is a dark grey thing about a half inch by half inch and has two wires going to it.
2helpful
2answers
When the DEW appears leave tv on for several hrs at room temp. The heat from the picture tube will help remove the moisture.
2answers
HELP, my panasonic keeps shutting off. Dew? condensation?
Put it in a very dry place, and let it sit for a few days. How is it getting either dew or condensation? Once dried out, keep it in an airtight plastic bag.
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
