Philips 42PFL5332D 42 in. LCD Television Logo
A
Anonymous Posted on Feb 07, 2018
Main board tv
My tv will turn on /off sometime come back on and sometimes not.Shop Jimmy recommended replace main board. Bought new (refurbished board from AV tech and installed board .Tv power light on but no audio or video......Do I need to reprogam tv if so do you have instructions......Please HELP.....
Larry
Level 3:
  • Philips Master 5,042 Answers
  • Posted on Feb 07, 2018
Larry
Philips Master
Level 3:
Answers
5042
Questions
Helped
1241800
Points
18413
Are you sure the board you received is good?...you should have bought the board from shopjimmy, then they would have worked with your fixing your set.
5 Related Answers
A
Anonymous
  • Posted on Aug 16, 2008
SOURCE: Replacing the Y-MAIN or Y-SUSTAIN Board in Philips 42PF9630A/#&
I called PTS 1-800-844-7871 they told me it was an easy fix. The part is $162.75. Im gonna try it.
Anonymous
  • 138 Answers
  • Posted on Aug 19, 2008
SOURCE: philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Anonymous
  • 138 Answers
  • Posted on Aug 20, 2008
SOURCE: Philips 42PF9630A/37 PLASMA TV
Replace that board the part number is 996500032643. go to www.vancebaldwin.com for the price of the board.
Anonymous
  • Posted on Mar 27, 2009
SOURCE: magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Anonymous
  • 44 Answers
  • Posted on Jun 25, 2009
SOURCE: Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
LCD TV backlight goes off but still sound is present. Sometime it happen within few minutes and sometime take 30 minutes plus. Is that inverter Problem or CCFL? how I can rectify?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
1helpful
Why does plasma TV have no picture?
What brand and model # is the tv? This is very important as far as researching your problem. You probably aren't the first or the only person with this problem. There are typically four to 5 boards including an x main, a y main, power board and others. Sometimes easy stuff like capacitors or fet's go bad and you can fix it yourself pending your soldering abilities. Sometimes whole processors go bad or entire boards and these need to be replaced. Sometimes people want to fix sometimes they want brand new
I have Lg 50pc3d-ud and it has very dark spots on the tv that moves around. The screen is also very dark no matter the settings. The dark spots aren't always there, they go away sometimes but if...
This problems ur tv are having only can be two causes 1) The Y-Sustance main tuner logic board or 2)The tv Plasma screen panel itself it is slowly leaking radiaton and dying,if it is the tv plasma screen panel itself it is dying than the tv not worth repairing because by replacing the plasma screen panel itself will cost the same as a new tv itself.The Y-Sustance board-that the tuner main logic board that take in the tv incomming broadcasting signal cable.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish Y-Sustance main tuner logic board for replacement.This tv problems are 50/50 between the Y-Sustance main tuner logic board or the very exspensive plasma screen panel itself.
2helpful
Power light flashing green. No other light or sound. Per directions I found here, I bought a new power supply board. No change at all. Any other ideas?
Ur tv still having the same result a flashing LED power light indication,after u change the tv power supply board.Mean only one thing the main logic Tuner signal board it is also dead too.The Tuner signal board that the board where the tv incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish main logic Tuner signal board for the replacement.Tries out the old power supply board with the new refurbish main logic Tuner signal board too 50/50 the old power supply could be still functioning.If ur old power supply board still good and functioning,than return ur new bought refurbish power supply to the vendor u bought it from to get some money back.
My Toshiba CZ32V61 sometimes works and sometimes doesn't. It just suddenly turns black or displays "snow". Sometimes, the red power indicator will flash and sometimes it doesn't. Sometimes the...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
3answers
TV has a mind of it's own. I turn it off & it turns itself back on. It pulls up the input menu without me hitting the input button. Then it switches between the input options without me hitting...
U have some skills like take things aparts and putting it back together again?Yes?The tv Tuner signal board have problems,might even be the CPU itself have some kind of shorts.The Tuner signal board,that the board,where the incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish Tuner signal board for the replacement.
1helpful
2answers
It keeps going on and off . It stays off a minute or two, then comes back on. Sometimes its very quick to go on and of and sometimes you can go all evening before it will do it
The power supply board have problems.That the board,where the power a/c plug into it.That the power supply board.Tries websites like Shopjimmy.com.Ebay.com to buy a refurbish power supply board for the replacement.
2helpful
4answers
Vizio LCD 37 Inch Turns Off Randomly
The main board has gone bad. Replace the board will fix it.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
