Refrigerators Logo
Anonymous Posted on May 31, 2013
Gss201epjww Freezer and freeze quit working
Anonymous
Level 3:
  • GE Master 1,606 Answers
  • Posted on Jun 03, 2013
Anonymous
GE Master
Level 3:
Answers
1606
Questions
Helped
570380
Points
5623
2 Related Answers
Anonymous
  • 263 Answers
  • Posted on Feb 06, 2010
SOURCE: The freezer has quit freezing. The refrigerator
your refrigerator 100% depends on the freezer (unless you have a sub-zero brand fridge, that has 2 compressors). So your fridge will be warm soon too. There is no fuse in the fridge. Try unplugging it for 24 hours and see if that helps, otherwise it's better to call for service.
Refrigerator repair orange county, ca
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Dec 09, 2010
SOURCE: refrigerator running getting cold making
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Whirlpool American fridge freezer FRSB36AF20/2 Triangle Warning light on and freezer not freezing. Fridge ok
Most common these symptoms point to a unit low on freon. The fridge gets its cold air from the freezer. So there is just enough freon for a good fridge temp but not to freeze water in the freezer.
Second would be the coils froze over due to the defrost circuit not working. Also check the conderser fan in the freezer. The cooling fan in the back bottom, if there is one, may have quit also.
Why did my refrigerator quit working but the freezer side still works?
Your freezer is probably froze up with ice. Pull all your food out of it and shut off the refrigerator. this will let the coils warm up and melt the ice.on the freezer coils. There are coils behind the freezer that freeze up up. I ran a hair dryer in there freezer on low for a few hours to speed up the process.
Feezer shut down with hi-temp alarm
Sounds like a defrost problem. Water came from frozen evaporator that thawed after being unplugged. It will operate great until evaporator freezes over again because it's not defrosting. Defrost components are defrost timer or Board, defrost heater, and defrost thermostat. One or more of those components have most likely failed. Also be sure Freezer / evaporator fan is working.
It just quite freezing model lffh2067dw3
I am going to give you the possibilities of why it quite freezing:
compressor not running
freezer fan not running
condenser fan not running
too much ice on evaporator coils
poor air circulation
blocked air vents
overloading food
defrost heaters not working
timer bad (if available)
t'stat not working
try to check what you can... if you are able to pin point let me know then we can take it from there. if not then give me more info so i can give you better help
Mar 11, 2010 • Freezers
Freezer portion doesn't freeze.
check settings. if good check if compresor is running. a relay on compresor could fail
Freezer and ice maker quit working / The temp.display on the door is just flashing .
There may be a fan that moves cold air in the freezer and icemaker compartment(s).  If the fan freezes up the cold air will not circulate.  Since the fridge compartment is still cold it does not sound like a compressor problem.
2answers
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
GSS201EPJWW side by side refrigerator
I HAVE TRIED A BLOW DRYER ON THE INSIDE OF THE FREEZER DOOR WHERE THE ICE GOES INTO FOR 5 - 10 MIN.AND IT STARTED WORKING AGAIN  :-)
Top Refrigerators Experts
vince
Johnny 1000
