I have a 6 month old 50 gallon electric water heater in the basement. I have always been able to hear upstairs it fill back up anytime water was used in the house be it flushed toilet, shower, dishwasher, sin etc. About three weeks ago, I started noticing the same noise of it filling up but this time it is MUCH louder. It is so loud the the sound resinates upstairs to at times it can drowned out the tv volume. It is not leaking nor am I having any problems with it heating or enough water. It is not making a pinging, cracking or banging sound...it just sounds like loud water running and it hasnt done that before. Any suggestions on what it might be?
Probably heat trap nipples, or other constriction in pipes.
http://waterheatertimer.org/New-water-heater-making-noise.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment and say what you find
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: 6 yr old electric rheem fury 50 gallon all of a
you have a couple things that may cause this. you may have a bad element a bad thermastat a tripped eco (emergency cut off ) or problem with electric suppling heater.if you have no electric backround or training you should call a pro
SOURCE: 50 gallon electric heater not working after about ...
Some elements will read with a meter good until they heat up.
Hot water then going to ice cold top element is working and bottom bad. Luke warm water and then goes cold bottom element good and top element bad.
Elements and thermostats are not to exspensive to replace.
If you have power only two thing's left are the thermostat's and the elements.
SOURCE: Every time we use hot water, our gas hot water
The down tube inside the tank is clogging up with deposits
SOURCE: I have a Rheem 80
To check to see if it is a bad element - turn the power off again and use a multimeter to check continuity (Ohms) in each element. It is not uncommon to have one element fail. Replacing an element is "elementary" :), if you have some mechanical aptitude. Just be sure and drain the tank to below the level of the failed element. Easier if it is the upper element of course. Again - be sure the power is OFF - check it with your meter before you begin and you may even want to lock out the breaker if there is any possibility of someone mistakenly turning it back on.
Testimonial: "Larry, Jason here, thanks alot. This is very helpful. "
