The tv was working until a power cut when the came back on tv did not this has happened three or four times each time the tv comes back on after two days or so
A hard reset must make it right. Do it. Unplug the TV from AC wall socket, and re-pug it back after 10 minutes or so, must reset it to a hard reset. If it do not help you, contact the Pansonic service center. A firmware update might be necessary. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
SOURCE: 42" panasonic viesta plasma tv cuts off after about 30 minutes
Adjust the automatic shut off settings on the set using the menu system. the newer models are programmed to shut down to avoid the burn-in problem associated w/ plasma scenes.
SOURCE: panasonic viera hd tv th 50pz80u
We had a Pioneer that did the same thing. We called a Pioneer Service Center. It appears there was a recall on the Power Supply. They fixed it in our home at not charge.
SOURCE: TV loses power
hi, this is typical capacitor issues. they are failing to hold there charge load. they will eventually blow and render the tv useless. these are located on the power board. i suggest a repair in the near future.
SOURCE: viewsonic 32" N3250W LCD TV won't turn on
by what you say it sounds like the power switch but i am no expert when it comes to tv's hope this helps regards Jim
SOURCE: I have 50" lg Plasma tv. When I start it first
The UF capacitors on your PSB-power supply board are blown. Your tv is putting itself in fault protection mode to keep it from damaging more components internally. Soon enough the TV won't come on at and you'll be left with a blinking fault LED.
