My shaver suddenly started to sputter when I switched it on and stopped working. However, it still switches on and indicates a full charge. The yellow cutter foil icon is lit. Would non-replacement of the foil cause the unit to not work? Should I just buy a new foil or is it likely another issue?
SOURCE: Loose Cutter Block
when you remove the cutter block is there a white nylon fixture atop the vibrating mechanism? this nylon piece snaps on the vibrating rod and the cutter snaps into the nylon fixture.
SOURCE: BRAUN 8595 screen indicates i should change my foil and block
there is a reset button directly underneath the LCD screen
SOURCE: how to disassemble Braun 4505 shaver. Cutter stopped working.
You want to go to this site and get a repair manual. http://web.archive.org/web/20041025223715/63.230.9.155/braun/Srv_Man/SHAVER/
Follow the instruction and remove the swivel head. Then remove the 2 screws at the bottom. I still have problem sliding the two side head support off.
SOURCE: Hi my Braun gives me the information, i have to
You can reset it very easily..here is the method...
There is a small button under LCD screen..If you push that button 3 times a message comes as "foil +cutter" push 4.th times than you will have a message"reset foil" and push again and keep pushing until flashing stops it gives "Reset OK" message..it is done..
That's all..
regards
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
