20 Most Recent Braun 5270 Epilator Questions & Answers
3answers
My Silk Epil 7 has
My Braun worked fine the last time I used it & would not come on when I tried it today. Worked on it & found it to be jammed with hair. Would not rotate. Scrubbed it with a toothbrush, started digging out the hair, forced it to rotate, scrubbed it some more, & rotated it some more. The more I worked with it the more hair kept coming out. It's rotating fine now. I think I'm going to clean it with my water pik. My Braun is the kind that can be used with water & the top part comes off. Haven't used it yet but I think I have fixed it. Wish I could get it apart to clean it out but the head of the screw is strange & I don't have anything that will turn it.
2/19/2020 12:29:52 AM • Braun 5270... • Answered on Feb 19, 2020
Plugged in india without transformer
It is hard to say. If the device has a fuse fitted inside then it may only be that needing replacement. If the motor or other circuitry is burned up, then just buy a replacement unit.
8/22/2017 4:14:19 AM • Braun 5270... • Answered on Aug 22, 2017
0answers
0answers
0answers
My braun silk epil xelle
Probably a whole bunch muck is inside theyre (science Project ewe), are you sure you want to open it up? ok... there should some screws underneath the plastic covering but you will need to kind of rip that off and reapply some sticky appoxy after.
7/5/2012 11:45:28 AM • Braun 5270... • Answered on Jul 05, 2012
I bought the silk epic abt two hrs backs. It was
I called Braun at1-800-BRAUN-11 (1-800-272-8611) and learned that you may need to remove the head and replace it. If that doesn't work, it may need servicing. Hope this help!
6/29/2011 3:41:21 PM • Braun 5270... • Answered on Jun 29, 2011
My braun epilator has stopped working
Braun Authorised serivce: Unique Services Bldg No.3, 1st Floor, Office No. 3, Navjivan Society, Lamington Road, Mumbai - 400 008.
Call. 23051554/23095757 Contact; Mr. Ashok
12/1/2009 7:24:12 AM • Braun 5270... • Answered on Dec 01, 2009
0answers
I have a Braun shaver S7. The cleaning charging station has stopped working unless I sit there and hold the button down. How do I reset it?
The button will be part of the control board, and needs replacing. If you can remove the base and get inside it, you may be able to clean the back of it with Electrical Switch Cleaner.. I Braun Service Centre could get parts and repair it, or you can replace it and get a brand new charger / cleaning unit. There are some videos that _may_ help. https://www.google.com/search?q=braun+shaver+s7.+the+cleaning+charging+station+button+not+working
Braun 81622438 Series 7 Pulsonic Clean & Charge Station
Mercury Shaver Centre https://www.shavercentre.com > canada > braun-816224... Description. Original Braun 81622438 Clean & Charge Station for Braun Series 7 Pulsonic self-cleaning shavers. Please check Model/Type listing before ordering. $89.95
Braun Clean & Charge Station for Pulsonic Series 7 ...
Amazon.com https://www.amazon.com > Braun-Charge-Station-Pulso... SHAVER STATION: Braun Pulsonic Series 7 shaver charging base has an automatic program selection and fast clean feature. HYGIENIC: Removes shaved stubble ... Rating: 4.1 · ‎40 reviews · ‎US$79.99 ..
5/14/2024 1:28:08 AM • Braun Health &... • Answered on May 14, 2024
Diode laser hair removal is better than IPL or DPL?
All the details Anna, starting with the conclusion. CONCLUSION. To conclude, diode lasers are better for hair reduction and pigmentation removal, while IPL lasers can be more versatile and can address a wider range of skin concerns. The choice between the two will depend on the specific needs and goals of the patient. Jan 31, 2023
IPL vs Diode Laser Hair Removal - Cosmeditech
Cosmeditech https://www.cosmeditech.com > News > Blog
Diode Laser Hair Removal VS. IPL ...
Spotless Laser https://spotlesslaser.com > blog > diode-laser-hair-remo... Diode laser hair removal is more comfortable because of the integrated cooling and treats more hair and skin types, whereas IPL is best suited for those with ...
The Difference between IPL & Diode Laser Hair Removal
Oxford Laser Aesthetics https://www.oxfordlaseraesthetics.co.uk > Blog The treatment methods outlined above mean that, typically, IPL technology will require more regular and long-term treatments for hair reduction, while diode ...
Difference between IPL, DPL, SHR and Laser Hair Removal
bioaesthetic.com.sg https://bioaesthetic.com.sg > ufaqs > what-is-the-differe... Aug 10, 2020 - Even though DPL is an advanced form of IPL, it is effective and quick in hair removal when compared to IPL. It removes all the gentle and small . ..
2/28/2024 7:45:44 PM • Braun Health &... • Answered on Feb 28, 2024
Braun Battery dead How do disassemble it
Braun Series 3 Electric Razor disassembly and battery replacement (original and AA NIMH batteries) (youtube.com) Braun 9-in-1 Trimmer - Disassembly/Battery Replacement (youtube.com) Remove the Screws: First, you'll need to remove any screws that hold the device together. Look for visible screws on the casing or housing. Use the appropriate screwdriver (usually a Phillips or Torx) to carefully unscrew them. Open the Casing: Once the screws are removed, gently pry open the casing. Be cautious not to damage any delicate components inside. You can use a flathead screwdriver or a plastic opening tool for this step. Access the Battery: Inside the casing, you'll find the battery. Depending on the specific Braun device, the battery may be soldered in place or connected via a connector. If it's soldered, you'll need to desolder the connections. If it's connected via a connector, carefully disconnect it. Replace the Battery: If you have a replacement battery, insert it in place of the old one. Make sure to observe the correct polarity (positive and negative terminals). Secure the battery back in its position. Reassemble the Device: Put the casing back together, aligning all the components properly. Screw it back in place. Test the Device: Once reassembled, check if the device powers on. If it does, congratulations! You've successfully replaced the battery.
2/12/2024 3:40:02 AM • Braun Health &... • Answered on Feb 12, 2024
Replacing motherboard on Braun Series 5 Shaver
I have the same shaver. The motherboard is simple, it has an electronic on/off button, a charger control and that is it. Nothing to program. Help here, but I would let a Braun Service centre do the job. Getting inside can be tricky. https://www.google.com/search?q=Braun+Series+5+Shaver+replace+motherboard ..
11/29/2023 12:46:01 AM • Braun Health &... • Answered on Nov 29, 2023
Braun 5270 Epilator Logo
Popular Tags
24 questions posted
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ZJ Limited
ZJ Limited
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Braun Health & Beauty
Most Popular Question
silk epil 7
  • Health & Beauty
