Fuji FinePix F40fd Digital Camera Logo
Posted on Mar 16, 2009
Photos saving to camera internal memory not to memory card.
Want to change settings so photos save direct to memory card but cant work out how to change settings. Fuji finepix f40. thanks
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
512
Points
8
Go into memory on menu and choose change memory settings from internal to card
How do I save to my internal memory of my digital photo frame ?
Usually, the camera saves to internal memory when no card is present. Internal memory is not large. More for holding a photo or two until you realize there is no card there. When you do save to internal memory you then need to transfer the images to a card, or plug your camera into the computer and transfer the images that way. Hope that helps.
Oct 18, 2014 • Cameras
Photo not saved in internal memory
You have to set your camera to save to internal memory... It usually does so when you take the SD card out... It will then default any pictures to internal memory... If you set a picture as a screensaver it will automatically be saved on internal memory too.
May 09, 2012 • Cameras
Sometimes pictures show up on memory card of GE x5 cam. sometimes they don't. what could be the problem?
You have an internal memory and memory card selection on your camera. If you have it set on internal memory you can take photos but they won't show up on the memory card unless you save them over to the card. Change your settings and this should fix the problem
I have a fujifilm finepix s1600 and it doesn't save my photos anymore. the photos aren't save neither in the internal memory or on a memory card. after i make a photo and press de display button it...
I wish manufacturers would eliminate the internal memory....it causes nothing but problems for us. Try this...with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, download any pics from your memory card using a separate card reader if necessary. Then, format the card in the camera. After this, your card should work.
Oct 31, 2010 • Cameras
I have a canon a470 ps i installed an canon sdc-32m card in it but still its captures only 12/13images...?
OK OK i understand . go setting in camera & save change the photo storage device in your memory card. i am 100 % sure right now all photos are save in your camera internal memory. just transfer it in memory card .
1helpful
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • 2helpful
    How do i switch off internal memory
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
      After you have done so I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • 3helpful
    Transfer internal memory to memory stick. Olympus camera
    Place a memory stick in the camera. Next, go to MENU, then press BACKUP. This will save your internal images to media card.
    2helpful
    2answers
    I have a new memory card. I cant get pictures
    Your camera is only supporting SD/MMC Cards (up to 1 GB)
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    1helpful
    My pictures were not saved on my SD card so where did they go if they did not go in my internal memory?
    They may have been saved to the camera memory - Most cameras have a limited amount of internal memory - If they ae saved to your camera and not SD card, you can still transfer to them your PC via USB cable.
    You can check where the photos were saved to by checking the settings on your camera/ menu/ settings/ default
    Top Fuji Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
