Can you help me how to change the light Bulb of my microwave as the manual doesn't have any step wise description, how to change the light bulb?
It is Sanyo EM-SL100N model.
Thanks
Furness
could you please let me know how to approach the bulb as there are only 2 screws inside and neither of them leads to any bulb.
Please help me out with this.
Thanks
Furnesscould you please let me know how to approach the bulb as there are only 2 screws inside and neither of them leads to any bulb.
Thanks
Furness
You can't post conmments that contain an email address.
https://www.youtube.com > watch
1:27
Watch our simple step by step instructions to replace the bulbs in your Bosch oven.
YouTube · Bosch Home Appliances USA · Aug 31, 2018
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation.
Step 1
Unplug the Sharp carousel microwave from the electrical outlet.
Step 2
Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3
Lift off the covering.
Step 4
Locate the bulb and unscrew. Screw in your new bulb.
Step 5
Replace the cover and screw back tightly. Once done, test your new bulb.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
·Close light cover and secure with screw removed in step 2.
I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Light bulbIf your
microwave light bulb is not working, perhaps it has blown. The first
step is to replace the bulb and power on the microwave. If this does not
correct the issue, the next step is to check the socket and wiring to
verify if that is the problem.
Light bulb socket & main control boardIf
your microwave light bulb is not working after the installation of a
new bulb, check the light socket as well as the wiring to ensure they
are properly operating. If these sources are functioning properly, the
next step is to check for a faulty control board as a possible root
cause to your microwave light bulb malfunction.
Light bulbIf your
Buy a different brand of Microwave. This is ridiculous! We are now buying a new microwave - a different brand, one that has a light bulb that is easy to change
Hi, If you put in your search engine
Panasonic Microwave Model T 784. bulb replacement
You will get a selection of web sites. Scroll down and select the 5th site. At the right hand side there is a series of options, chose the top one "howto man" There you will get a step by step guide to changing the bulb in your microwave.
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Thanks
Furness
