The projector, which has no on/off switch, was left plugged in to main supply. The power LED stayed on and it operated normally when used. I then decided to disconnect the supply when not using the projector and the next time I tried to use it the LED did not light up and the projector did not work. I left it plugged in and after a short while (+- 5 minutes) the led came on and the projector worked normally. This happened twice although the second time it took about 25 minutes for the led to come on. On the third occasion it did not work at all.
There seems to be problem in your power supply. Look for any swollen capacitor --- generally 3300uf, 10V. Be careful about the polarity of the capacitor before you take it out. Check the capacitor to make sure how it's mounted ( for polarity purpose). Negative side of capacitor will be toward the outside of pc board. Substituting 2200uf, 16V capacitor for 3300uf, 10V will work ok.
