Coby MP715-4G  Digital Media Player Logo
Posted on Mar 14, 2009
Cannot connect Coby MP715 4gb to computer
I can't sync it to windows media player (to add songs), and "My Computer" does not show it like it should. The computer detects the player for about thirty seconds and then says, "Found New Hardware: A problem occured during hardware installation. Your hardware may not work properly." Plus, it once detected it as MP715, then once as MPT. Is this a defective product?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1224
Points
I had this problem as well with xp, I tried a different usb port and it worked right away.
Joy
Anonymous
Level 1:
  • Posted on Apr 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1224
Points
All windows 2000/xp/vista should be able to recognize the system without a problem, however if you are still using windows such as 98 then u will need to install the driver. the right driver for win98 can be download from the product site.
note: it has to be the right driver(win98)
I ADDED SONGS TO MY COBY MP815 USING WINDOWS MEDIA PLAYER AND NOW IT WONT TURN ON. I PLUG IT INTO MY COMPUTER USING MY USB AND WHEN I UNPLUG MY USB FROM THE MP815 THE SCREEN FLASHES WHITE FOR A QUICK...
Assuming the player is charged. (For charging always connect directly to the computer, not through a reader or hub).
When buttons on the player do not react, reset the player:
Disconnect the player from the computer.
See that the HOLD button is not engaged.
Gently push the RESET button on the rear side: use a narrow pointed
object, like a paperclip.
Did synchronization of the songs in Windows Media Player fail ?
For transferring songs, check in Windows Media Player:
1. The player is detected in Windows Media Player 10 or higher.
2. Setup the Library / Add to Library: add the location of songs you want to transfer in the library.
3. Create Playlist; give the list a name and put songs in a playlist
4. Sync Playlist: transfer the list of songs onto the player and wait for the message until you're allowed to disconnect.
1helpful
How do you download songs from computer's music files? I copied and pasted from my library,they appear on the player when connected t computer but are not there when disconnected?
Transfers onto he MP815 can be done through exploring 'My Computer':
Music files must be copied into the Media folder of the player.
In this mode, the player shows as a removable disk in the computer folders.
Before disconnecting the player, always go through the safely remove hardware icon in the right corner below on the computer's screen.
When you're using a software program (e.g. Coby Media Manager or Windows Media Player) for transfers, use the help function in the software.
For Windows Media Player 11:
0. The player should be detected when you connect the USB cable.
1. Setup a library in WMP 11 [ Add to Library ], so the player knows the location of your music files.
2. Create playlist: put songs in a list
3. Sync the list onto the player
4. Wait until synchronizing has finished
Do not disconnect while sync is busy: a message appears when you're allowed to disconnect.
How to get songs back in the coby mp3?
On the MP610 you could use either Windows Media Player 11 or Coby Media Manager for transfers of songs.
Next steps are important for adding files onto the player:
1. The player should be detected in the software for transfers, when connecting the USB cable.
2. Setup your library in the software (Add to library): There has to be a list of folders in the software manager, where your music is located on the computer.
3. Create a playlist in the software: make a list of songs, you want to transfer onto your player
4. Sync the playlist onto the player.
When needing more help, just add text in this reply.
2helpful
I cant get my coby mp 815 to pull up its music manager on my new computer, I pluged it in, but it just plays whats already loaded on it? whats the music manager?
If I was you I would use either Windows Media Player or Drag and Drop your files to your player. If you choose to use Windows Media Player you will have the same functions that you will have with the coby music manager. Here is the following ways to add music and files to your player if you choose the above ways to add music:
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder; available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
1helpful
I cant download music into it
Thry the solution below. If it does not work then you need to reformat. Also you might want to go to the coby website and download a updated version on the firmware and reflash your player. This will set it back to factory settings.
  1. Open Windows Media Player.
  2. Find and click the "Sync" tab. This is located at the very top of the program.
  3. Plug the Coby mp3 player into one of the USB ports found on your computer. Depending on the exact Coby mp3 player that you own, you can either plug the player directly into the USB port or by using the cord that came with the Coby mp3 player. The name of the Coby mp3 player will appear in the top right corner of Windows Media Player.
  4. Click "Library." This link will be on the left side of the program.
  5. Double-click the "Songs" option in the middle of the screen.
  6. Scroll through the list of music on your computer until you find the songs you want to put on the Coby mp3 player. Right-click on the title of the song and a drop box will appear. Select "Add to Sync List." You will then notice the song listed in the column located on the right side of the program.
  7. Repeat the previous step until you're finished putting songs on the Coby mp3 player.
  8. Click the "Start Sync" tab located beneath the list of songs you chose in Step 6. Those songs will then be added to your Coby mp3 player.
2helpful
I don't know how to download music from saved files on my computer.
You have to use Windows Media Player to Sync music files from your computer to the Coby mp3 player.
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
1helpful
2answers
Can't delete songs from coby mp-c827 player
Use Windows Media Player:
My Directions:
Coby MP-C827 MP3 Player Problem:
Use Windows Media Player instead:
My Directions:
CANT ADD OR DELETE MUSIC NEED HELP
My Directions:
Top Coby Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
