Ok...something wierd is happening with my computer i few days back i started building my own computer with a:
ECS elitegroup GF7100PVT-M3 motherboard a Pentium 4 521 LGA775 800 MHz Processor and Foxconn Fan/heatsink a nVidia GeForce 8400 GS video card 2 Kingston 1024MB PC5400 DDR2 667MHz Memory modules a 120 GB Seagate Hard Drive and a Power Up ATX Mid-T case with a 450w PSU
Sometimes the computer wont turn on at all, or sometimes you have to physically lift the fan (put pressure on it so it goes up maybe 1 mm) so it will work. Sometimes the PSU works fine, but sometimes im not so sure about if its working or not. I think i blew out the CPU_FAN connector on the motherboard so right now im using the SYS_FAN connector. If you want the fan to start, you have to lift the wire that goes to SYS_FAN a bit so the fan can turn on. Lately, nothings been working at all...
What size power supply are you using, if its under 400 watts it may just be under powered. Large video cards 512mb and over take a lot of power. Try removing the video card and see if you can get the pc to power up, hopefully you have on board video.
How did you blow the cpu_fan connector, did you short it out? I would first supect the power supply is under rated, second a blown power supply, or mother board.
First thing I would do is try using the monitor on another working computer to see if it works. If so, you have eliminated that as an issue.
Kind of hard to fathom that you got two fubar mo bo's but as they stay in the street, sh-- happens. However, The lack of a beep means that the bios is not posting. When you turn on a computer, the bios does a check of internal components and environment - if all is ok, it beeps and then has the hard drive install the operating system into the computer's memory. And if something is wrong, the bios will usually give out certain beeps that are coded such as when you have bad memory, no memory, etc. But you are getting zippo, and no video at all on your monitor - this is one of the few times you wish you had the blue screen of ***** because with that at least you know your hardware is ok but your software has an issue.
The conditions you have reported would seem to indicate that the bios chips on both units are corrupted and not working. U might also make sure that the memory chips are good. A bad chip, not a missing chip, will sometimes prevent the mo bo from booting up.
If you also remove all the memory and turn on the witch, if the bios is working it will beep like crazy. If nada, bios is dead.
If boards are new as you indicate I would return for exchange.
Sounds like a electronic spark module. You need to check if this happens again if it has spark at the end of the plug wires. At least if we know it has spark when this happens we can look at something else. If you take one wire off if this happens again take a paper clip or screw or anything metal and insert it into the wire boot. Lay it on the block of the engine and have someone turn the engine over while you watch for spark. If there is spark then we can move onto something else.
the beeping is post codes. they are telling you something is wrong. the code is a code for what is wrong like 3 beeps 4 beeps 1 Beep then repeatsthat code is 341. first thing i would do is pull out you ram and reseat it. that is the most common problem.
The Power Buttons
electrical circle sometimes just braked it by one of sensors and the
result is the 2 beeps and Power Supply is in protected mode error.
The
whole computer is turn off but the power button is turn on and this is
the nub of the matter. Because if you want turn on the computer you
can't because already turn on but just the Power button and you can't
do anything.
The solution: You need just change the Power
Supply and don't do anything just the power cable put into the Power
Supply after turn off computer. Finaly change back the Power Supply.
I have the 6100 sm-m and was having same problem .. I went to ecs website and flashed to old bios then downloaded new bios ... when updating make sure you check the bootblock , dmi, and hole .. I also checked the update all ... seems to have fixed the loading of vista and has not shut off
This sounds like a dead hard drive. Still, you may want to try:
1. Enter your CMOS/BIOS and verify that your laptop can detect the hard drive. Further check if it is configured to boot first from the HD;
2. Slip in your XP or Recovery CD and boot from that. It may be that the boot section/files of your HD got messed up. When prompted, instruct the CD to repair;
3. Remove your laptop's HD and connect it to a 2nd PC as an external/removable drive using a 2.5 enclusore with USB attachment. Thereafter proceed to diagnose, check and hopefully recover your important files;
4. If confirmed of a defective HD, replace and reinstall your OS.
Hope this be of some help/idea. Post back how things turned up or should you need further information.
Good luck and kind regards.
Try putting your windows cd in before you boot up to see, when it starts up if your laptop is set up to boot from cd.
If not, can you press F2 or DEL on boot up to see if you can enter the bios screen.
Come back here.
