Came home one day to find 1,000 songs out of 4,000 were gone from itunes library along with all playlists. All songs & playlists are still on ipod, though. If I dock ipod into computer for update will it wipe out the 1,000 songs & playlists as the "update"?
If you synch it yes it will wipe it out - you can get software to back your ipod back to your computer so I would personally delete all the play lists and re do it. your music will be in my documents --> music --> itunes so you can re add it that way and re sort the playlists.
If its on mac os then it will be under your music folder ( macintosh hd --> users --> your username --> music --> iTunes
It may be that your itunes library file may have gotten corrupted so once you have gotten it sorted out close down itunes and go back into your music folder and itunes folder and make a backup copy of your itunes library files.
Assuming your not moving your music files around in side of the music or itunes folder it should be fine.
To Transferring Playlists If you want not only your content but also your playlists to exist on your new computer, you will want to transfer a copy of all your playlists from your old computer. To do this, choose File > Library > Export Library on your old computer. Save the XML file that is created to your desktop. Send the playlists file to yourself as an e-mail attachment, use an external drive, or use file sharing to move the playlists file to your new computer. Once the file is on your new computer, open iTunes and choose File > Library > Import Playlist. The import process will remove any items from the playlists that you didn't share via Home Sharing. Source:http://support.apple.com/kb/HT4527 Alternative Method: http://helpmerick.com/how-to-transfer-your-itunes-library-playlists-to-a-new-computer.htm
