Computers & Internet Logo
Posted on Mar 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Saving my scrapbook file to jpeg file
All my scrapbook works were save in *.scrapbook. I would like to save in others file extension (ex. *.jpeg or *.pdf).
Anonymous
Level 2:
  • Expert 122 Answers
  • Posted on Apr 29, 2009
Anonymous
Expert
Level 2:
Answers
122
Questions
0
Helped
33982
Points
204
Go to file/save as
change the name of the file, make sure that <.scrapbook> is not in the name
the box under file name, you can change the extension, just scroll down to find the extension you want
Windows 7 PC, can't save my CK pages in .pdf
Reinstall Creating Keepsakes as an Administrator, as it reinstalls it will process your registry changes and should operate correctly
1helpful
3answers
New all in one printer/scanner. when I scan I get:- Adobe reader could not open 'scan_Doc0001.pdf'
Might need a bit more information about this: But I'm presuming you scan your document and save it as a pdf document using the built in HP software?
Couple of things to try:
1 - have you got the latest version of Adobe Reader? It may be that you are using an older version - the pdf document specification has been updated over the years and it may be that you're saving the pdf using a newer version of the pdf format than adobe reader is able to read.
2 - Adobe reader isn't the only pdf viewer, there are numerous other pdf document viewers (some free some not) You could try another pdf viewer, like Foxit Reader (free to use) and see if that can open it?
3 - When you save the scan, make sure that in the Save Dialog box it is really saving it as pdf. Common mistake is that people often just save a file with .pdf and expect the program to know that you want to save as pdf. When you scan there are several other file formats that you can use (Tiff, Jpeg etc) Is is possible you're saving the file as Tiff or Jpeg but with a .pdf file extension? If you're not sure, re-scan the document and resave it, but don't use a file extension, let the scanning program do that, see what it saves it as?
4 - check where you're saving the pdf on your computer? Is the place you're trying to open it from, the same as the place you've saved it?
2answers
I cannot print pictures taken in nef format. Can
Hi dear, most printers can only use jpeg or bmp format .Use Irfanview to convert raw file to either one.
1helpful
I HAVE A LEXMARK X9350 AND WHEN I SCAN ITEMS, THE FILE SIZE IS HUGE. EG 1 PAGE = 3MB. HOW CAN I REDUCE THE SIZE OF THE FILE
See the manual for X9350 on page 119.
The software application must be used for saving files to a specific format that you can select from the menu on the computer.
Standard scans are often saved as bitmap with the extension .bmp .
Select another file format like jpeg with the extension .jpg or .jpeg, when you want to view the scans in photoview afterwards.
Another option is to save the file in a format that can be read with Adobe Reader, selecting .pdf format.
A last option is to reduce your file size, changing the scan settings:
( I wouldn't advise; this can result in unclear copies ):
Advanced scan settings can be changed on the computer as well:
See reducing e.g. "scan resolution" and "color depth" on page 120.
Use the link support for Lexmark 9300 series for more help.
1helpful
2answers
Paint cannot save file windows 2000 proffessional
This fix should allow you to use MS Paint to Open and Save JPG files, and Open and Save GIF files. The quality of the saved GIF with MS Paint may be reduced because of the limited 256-color palette (See here for an explanation and workaround). A better alternative for opening and saving JPG and GIF files would be to download and install a great FREE image viewer called IrfanView (MS Paint is still better for individual pixel editing, so it's good to have both).
If you want to proceed with the MS Paint Fix, you should first do a search on your hard drive to see if you
have the jpegim32.flt and gifimp32.flt filters.
You can find those files here:
http://www3.sympatico.ca/one.human/files/Jpegim32.flt
http://www3.sympatico.ca/one.human/files/Gifimp32.flt
You need to make sure you have both filters in the following folders:
C:\Program Files\Common Files\Microsoft Shared\grphflt
C:\Windows\MsApps\Grphflt
You may already have the JPEG Filter on your system, but only in one location. If that is the case, Copy and Paste it to the other location. Once you have the JPEG Filter in both locations, you may only need to do a simple Registry edit to be able to "Save As" a JPG.
If you already have the JPEG Graphics Filter on your system (and in both locations as stated above), but MS Paint still won't let you "Save As" JPG, you can manually edit the Registry to correct this. It's a simple fix. Go to Start, Run, type REGEDIT, and click OK. Go to this key by clicking the + signs beside the keys (folders):
HKEY_LOCAL_MACHINE\Software\Microsoft\Shared Tools\Graphics Filters\Export\JPEG.
Click on the "JPEG" key (folder) in the left pane, and you'll see a String Value in the right pane with the name "Extensions". Make sure under the "Data" column it shows only "jpg". If it shows "jpg, jpeg", double-click on the "Extensions" string and from the "Value data" field remove "jpeg" so that it only reads "jpg" (without the quotes).
If it worked, this edit allows you to "Save As" JPG. If it didn't work, or if you want to be able to also open and save GIF files, read on.
Or use this reg file to export your files as jpeg
http://www3.sympatico.ca/one.human/files/Filter_JPEG_Export.reg
I have a problem that it does not appear my photos but recognize the usb
What kind of pictures are you saving? Ex:jpeg, digital images, etc
Also could be the excesive amount of using the usb's memory saving files, images, videos, etc,,deleting them and saving new ones back again.
Stephen
Photos I burn on computer jpeg image dont play on philips recorder dvdr recorder [email protected]
alot of DVD players wont play jpeg files try saving the pics as a gif or other type of file to see if the DVD player will play them
2helpful
3answers
Setting the format of the picture i scan
Ok I am not sure why ya scanner won't save in JPEG .. however converting the files to JPEG is relitively "Simple". After saving the Scanned picture.. Open it up in say MS Paint, Painshop etc, then simply choose "Save As.." from the File Menu, and save it as a NEW image file this time with a JPEG extension. IE: origional... picture.png or picture.bmp ... save as ...picture.jpg .. ya should be good to go. :)
Saving photo files
The building blocks of your image library are the actual file formats in which you save your images. There are two major formats: compressed and uncompressed. • The advantage of uncompressed storage is that you can save a maximum amount of image-forming information for color fidelity and clarity. • Compressed file formats get rid of some information to shrink the file size (thereby increasing a disk's storage capacity). We recommend saving all your work-in-progress images (equivalent to the negatives in film cameras) as TIFF files. This way they will remain at maximum quality, so you can create other versions for printing or e-mailing, and can save them in smaller, compressed files like JPEGs. The advantage is that you'll always be able to recreate an effect or enhancement by starting with the original TIFF file without losing image integrity.
Grand Canyon Tech
Grand Canyon Tech
