After running the initial channel search we can get only the first 3 channels. We are comcast cable subscriber and our other tv's work.
Make sure the tv is set on cable not antenna setting,this on menu then setup
If you use a top of set box this may be the problem. The tuner in the set could be bad but that don't happen very often. Some place you have a cable splitter that can go bad. Try anothe set on that cable line if it works ok then it is the set
