Usually this is a cam position sensor I have found this problem many times by replaceing the camshaft position sensor I believe this will solve your problem if this is helpful please leave good feedback
Testimonial: "Thanx Ken, It solved the Problem. How do I leave you A 100% Good feedback?"
SOURCE: Ignition will not recognize the key chip and it will not start.
call a locksmith they have a reader and can tell if your key is the problem... it will tell them which keycode is for your vehicle and they can check and see if the key matches also i have a 95 ssei and the pcm was the problem with mine
SOURCE: 2004 Ford Explorer 4.0 v6 will not crank
You have a fuel reset switch that needs to be pushed back in. This is why you are not getting any thing to happen
The fuel pump inertia switch is located in your right front passenger
area. It is located on the right side of the transmission hump on the
toe board, just under the edge of the carpet. If you don't see any gas
leaking, or smell any gas, push the button down that has popped up
on the top of the switch. This will allow power to go to your fuel pump.
SOURCE: 2006 Hummer H3 intermittenly wont start. Have to
Hi, my research on this issue has turned up phantom causes as sticking valves, ignition switch and seat movement.
On some Hummer, it turns out to be sticky valves in the head. GM replaced the head under warranty and the hummer haven't had any more trouble out of it. There is a recall for the 2006/2007 5 cylinder models and you should be able to have this taken care of at no cost.
Do you have a remote start?
The H3 Bypass module has an issue with Remote Start. When this happens to you must wait 10 full minutes before trying to start it again (DONT USE REMOTE, USE THE KEY) the bypass module takes 10 minutes to get out of "theft mode" this is in your manual as well, I forgot what page. The only way to get this to full proof work is to get a shop to "OLD SCHOOL" wire around the bypass module.
SOURCE: I have a 95 firebird.
It's when the security light starts flashing that the infamous "chip" in the key becomes a nightmare to many. Gradually the car begins not cranking anymore or if it cranks it would start and die in a second. Randomly it will do this more and more often until it won't start anymore. VATS, PASSkey and Passlock immobilizer systems are killing cars all over North America, they have a short lifespan and are certainly more effective against owners than thieves. Here is how you save your car
1st trick, Try a spare key that is newer or used less. The pins wear down and so do the keys causing security fail. 2nd trick, (if not starting) turn the key forward 2 clicks till right before it would normally start, leave like that for 10 minutes. ( no less ) After 10 minutes, turn key back then forward and your car might start. I did this in my regal for more than a year. If its shutting down while running, im sorry i have no quick fix... If anything on this page helps you, please remember to comment or give me a thumbs up on the myfixya sight so i can have a better rating to help more people on this. Thanks
Cheap fix: Bypass the chip in your key. Temporary, but effective. Until the TDM (theft deterrent module) in the dash poops out, then you're kinda screwed. I was told that these types of key security systems have a 7-10 year life span. Sucks for us. This link explains the "Key Issue" pretty well.
----- http://vats.likeabigdog.com/
Never worry again fix: Bypass the whole VATS/Passlock/passkey I or passkey II system entirely. Literally take it out, and throw it away. I just did this in my Regal. Took about an hour. Took longer to find the thing than it did to fix the problem. They sell a unit for 200 bucks to totally bypass this system FOREVER. life time-money back and all that. Finally did this in my car. Well worth the 200 if you've looked into getting this replaced... Anywhere from 600-1000 bucks. If you do buy this, please purchase it thru this link. The cost is the same, but i get credit for the sale and im trying to earn my money back, as you will be able to do if you buy fron NewRockies and join the free affiliate program. Thanks
----- http://newrockies.ca?ap_id=judd0081 ----- With this fix, you can take that whole Vats, passlock, passkey system out of your car all together. Good info on both sites.
It works for:
Any GM or Isuzu Vehicle with VATS or PASSKey or PASSLock security systems.
If your car has the chip in the key or in the lock cylinder, then you can save it with this Full Bypass.
Trucks
GMC/Chevy
1998-2006 S10/T10/Sonoma
/Blazer/Jimmy
1998-2007 Suburban/Avalanche
/Tahoe/Yukon
1998-2006 Sierra/Silverado
2002-2008 Trailblazer
2003-2006 SSR
1998-2006 C1500/C2500/C3500
1998-2006 K1500/K2500/K3500
2003-2007 Hummer H2
Isuzu
1998-2000 Hombre
2005-2006 I280/I350
2007-2008 I290/I370
Cars/Vans
Isuzu
2003-2007 Ascender
Pontiac
1994-2003 Grand Prix
1998-1999 Montana
2006 Torrent
1996-2005 Grand AM
1994-1998 Trans Sports
1988-1999 Bonneville
1988-2002 Firebird
1995-2005 Sunfire
1996-2002 Trans Am
Buick
2004-2007 Rainier
1994-2005 Century
1993-2004 Regal
1982-1999 LeSabre
1991-1996 Park Avenue / Ultra
1994-1996 Roadmaster
1991-1996 Roadmaster Estate Wagon
1982-1999 Riviera
1988-1991 Reatta
1996-1998 Skylark
1982-1990 Electra (all models)
Oldsmobile
1996-1998 Achieva
1999-2004 Alero
1994-2004 Aurora
1998-2004 Bravada
1991-1993 Delta 88
1994-1999 Eighty-Eight
1991-1996 Nighty-Eight
1998-2002 Intrigue
1990-1992 Toronado
1994-1997 Cutlass Supreme
1997-1999 Cutlass
1997-1999 LSS/Regency
1997-1999 Silhouette
1991-1996 Custom Cruiser
Chevrolet/GMC
1998-2005 Astro/Safari
1998-2008 Envoy
2005-2006 Equinox
1998-2007 Savana/Express
1995-2005 Monte Carlo
1997-1999 Venture
1995-2001 Lumina
1988-2002 Camaro
1995-2005 Cavalier
1982-2004 Corvette
1994-1996 Caprice/Caprice Wagon
1995-1996 Impala SS
2000-2005 Impala
1997-2005 Malibu Classic
1997-2003 Malibu
Cadillac
1986-1993 Allante
1982-1996 Fleetwood
1985-1996 Fleetwood Brougham
1992-2004 Seville
1992-2004 SLS/STS
1985-1999 Deville
1994-1999 Deville Concours
1997-1999 Deville D'Elegance
1988-2002 ElDorado
1994-2002 ElDorado Touring
1999-2007 Escalade
Saturn
2000 LS/LS1/LS2/LW1/LW2
2001-2002 L100/LW100
2001-2003 L200/LW200
2001-2005 L300/LW300
2004-2005 L-Series
2002-2008 VUE
1996-2002 SL/SL1/SL2
1996-2002 SC1/SC2
1996-2002 SW1/SW2
SOURCE: My 2003 Frontier won't start.
Hi, there are several possible causes, but none will cause the engine light to illuminate. As you have already guessed, one possibility and the most likely is the interlock. It is fairly easy to check the interlock switch or even to fully diagnose the problem with a 12 volt test light or voltmeter, but I will need to know which engine you have to provide exact instructions. Please reply with your engine size.
Hello
The engine
and automatic transmission in this vehicles drive train
are fully electronically controlled by a computer called the PCM and
TCM (Power Train Control Module, Transmission Control Module). When a
problem like this or other drive-ability related problems occurs the
computer stores a record of the problem (there are of course some
exceptions to this, like the fuel pump, engine coolant temperature
sensor and MAF sensor for instance) in the form of a fault code in
its memory, to read these fault codes you must have the systems
memory scanned with a special tool. Once the fault code(s) are read
you then must perform the appropriate diagnostic testing to find and
resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL
A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR
HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
