2000 Land Rover Range Rover Logo
Posted on Mar 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Loud whistle noise
2000 RANGEROVER MAKES A LOUD WHISTLE NOISE AFTER CAR HAS WARMED UP.STOPS WHEN I TURN A CORNER.
Anonymous
Level 2:
  • Expert 398 Answers
  • Posted on Mar 07, 2009
Anonymous
Expert
Level 2:
Answers
398
Questions
0
Helped
221380
Points
974
Check out your power steering fliud and pump. make sure all of you belt driven motors are tight.
kellyjason
Level 1:
  • Contributor 3 Answers
kellyjason
Contributor
Level 1:
Answers
Questions
Helped
770
Points
9
Check your power steering fluid reservoir.
My car is making a loud whistling noise every morning when it warms up please if you can, can you tell me which belt it is that I can replace?
If it is a belt.... there is only one serpentine belt.
Does it go away after it warms up?
In the 90's Ford had a problem with the EGR valves that would "hoot" until it warmed up.
My car keep on breaks alternator belts and it also makes this loud whistling noise. I've put on a new water pump, 3 alternators and several alternator belts
make sure that the pulleys of all the driven equipment are in alignment and not at a bit of an angle to the axis of the drive belt
To break belts something is not lined up properly or something is not turning freely
2000 LINCOLN TOWNCAR SIGNATURE SERIES LIMITED EDITION WHEN I START MY CAR IN THE MORNING I HEAR A LOUD WHISTLE- ING NOISE FOR 15 MINUTES UNTIL THE ENGINE WARMS UP AND WHISTLE NOISE STOPS. I REPLACED...
well it may help if you open the hood, then start the car and see if that helps you locate the item which is whistling. many cars have a power steering pump which likes to whistle until it gets warm. generally this is less than 5 minutes, and that is more like a screeching sound. something is either blowing out or sucking in through a small orifice to make the whistle, you need to physically locate the source of the sound. many bearings are in there spinning and any of them can be doing a cold screech.
myself I have been know to use a BFS, which is a big long screwdriver, i touch the pointy end to each of the spinning components and put the handle end to an ear. yes this process is not suggested for people with long hair or just no damn sense. but as i move the pointy end from component to component i know immediately when i touch it to the screechy one.
1helpful
2answers
Whistling noise while driving
If it is whistling while you rev your engine (while parked), then most likely there is a leak or hole in your air intake or vacuum hoses.
Facts:
1. Your car creates a vacuum to constantly receive air from the outside.
2. A whistling noise is created when air travels through a hole.
Check all air pressurized ducts for holes or leaks.
Check air intake system for holes or leaks.
Loud whistling noise when travelling at higher speeds (ie above 50mph)
I had a problem with a whistling car after 50 mph and it turned out to be the front window gasket. I put silicone on the trim and problem solved.
3answers
Whistling Jeep grand cherokee 1999
Sounds like a vacuum leak. Check that all your vacuum lines are attached and in good condition.
5helpful
Pcv valve location
volvo s80 y reg 2.4 runs ok little bit lumpy tickoover when warm but very loud whistling noise take dipstick it stops but very big suction from tube not pressure it is not breather box under manifold
Top Land Rover Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Land Rover Expert? Answer questions, earn points and help others
