How to replace drum bearings
SOURCE: how do you replace drum bearings on a GE front
you can not. must replace entire rear of two piece drum that holds bearing. might not be worth time and costs!
Testimonial: "Thank you the info was very helpful."
SOURCE: The drum inside my ge wbvh6240fww washer is loose.
There is one bearing in rear tub/bearing is part of rear tub...To repair that unit you will need a rear tub/inner basket with spindal and possible a front tub if it damaged..If i was you I would price the parts b/c you may not want to repair it as it can be costly .....Good luck
i have the same washer and i had an expert come and check it out and they said it was the bearings in the drum. I was quoted $600 to fix the problem. what it is, you have to replace the the whole back half of the out plastic drum which have the bearings factory sealed on it.
