Can the AC input circuit be repaired? The "on" indicator lamp does not light up; there is no response when power switch is depressed.
Look on the back of the unit for input voltage rating. Many (but not all) power supplies are capable of automatically sensing input line voltage and changing to/from 120v/220v without need of a switch for the user to slide from one to the other. If it is only rated for 120 vac and you connected it to 220, the primary windings in the transformer cannot tolerate higher voltage and was likely destroyed. Replacing the transformer with a identical one should repair the unit. also be sure to check the fuse if there is one close to the transformer. It may on the other hand have a switching type power supply that has no conventional transformer but it is also this type that auto-switches input voltages.
Has fuse but it may have blown transformer
32-Way F Micro-Pack 100 Series (Blue)
Pin
Wire Color
Circuit No.
Function
E1
DK GRN
835
Entertainment and Comfort (E&C) Serial Data Communication
E2-E5
Not Used
E6
DK BLU
1796
Steering Wheel Controls Input
E7-E8
Not Used
E9
LT BLU
1405
Remote CD Changer Common Input
E10
ORN/ BLK
1406
Remote CD Changer Left Channel Input
E11
LT GRN
1407
Remote CD Changer Right Channel Input
E12
BRN
199
Speaker Feed-Left Rear
E13
YEL
116
Speaker Return-Left Rear
E14
DK GRN
117
Speaker Return-Right Front
E15
LT GRN
200
Speaker Feed-Right Front
E16
BLK/ WHT
351
Ground
F1
ORN
640
Fused Battery Feed
F2
YEL
43
Fused (Retained w/KP2) Accessory Power Feed
F3
DK GRN
145
Radio Switched Power
F4
GRY
8
Interior Lamp Dim Switch
F5
YEL
32
Fused Interior Lamp Dim Signal
F6-F10
Not Used
F11
BARE
2011
Remote CD Changer Drain
F12
TAN
201
Speaker Feed-Left Front
F13
GRY
118
Speaker Return-Left Front
F14
LT BLU
115
Speaker Return-Right Rear
F15
DK BLU
46
Speaker Feed-Right Rear
F16
Not Used
