Reset digital timers before programming to eliminate trace testing memories and restore full functionality
Make sure you're in correct mode fro programming: Time setting mode, with selector moved to top next to clock symbol
Compare your timer manual with Hagar manufacturer's generic manual for the 2-channel: English on page 3.
http://waterheatertimer.org/pdf/Hagar-monotron-200-2-channel-manual.pdf
http://www.credaheating.co.uk/assets/kb/operating_instructions/0/Flash_2S_Programmer_Instructions_Issue_1.pdf
Contact Creda
www.creda.heating.co.uk
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: find manual for woods 59028 programmable timer switch
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
SOURCE: set timer for the 7-day outdoor timer i.e. 5:00 pm
Outdoor timers
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
HB88RC timer
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC Manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
Timer takes AA battery installed from back
Instructions say: Set timer to AUTO using MODE button. This will let programs run.
To override current program, press MODE once for ON-or-OFF override.
Press MODE again to enter RDM or random mode. RDM shows on display.
Press MODE third time for AUTO. Usually, AUTO will show on display.
SOURCE: 'Select' button not working properly
Timer is not identified.
Copy following link to read specific troubleshoot steps, and help identify specific timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
With digital timers, be sure to reset timer before programming, to clear stray memory traces. Repeat reset more than once.
Most timers today have 1 year limited warranty against defects in workmanship.
Brand name timers such as Woods, Intermatic, GE, Westek, Utilitec have specific warranty procedure, while promotional timers sold under Timex, First alert, Stanley, the warranty is less clear and probably underwritten by seller.
Add a comment with clear description of timer.
SOURCE: TRAX single channel hot water 7 day 14 settings programmer instructions missing
1) Thank you for description:
Copy following links to identify possible match for TRAX timer, and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TRAX
http://waterheatertimer.org/GE-timers-and-manuals.html#DIGI
2) Add comment March 2013 and say how closely this information matches your timer. Attach image.
Testimonial: "I think you have solved my problem. The Grasslin Tactic 371 instructions look as though they will work. Display looks very similar. I just need to try them out. Thank you very much."
