20 Most Recent Intermatic HB88RC - 7-Day Programmable Outdoor Timer - 15 Amps - 120 VAC Li Questions & Answers
Just program it as noted previously and put the timer in Auto. Set the clock to 1 min BEFORE your earliest timer program is set to come on. When the clock hits the correct time, it will turn on. Then set the clock to the correct time and you're golden.
Intermatic... | Answered on Oct 21, 2015
No, you do not need to set all 7 timer events.
When event1 ON and event1 OFF are set, press CLOCK button to exit programming and save programs. Or press PROGRAM button and move to event2 ON and event2 OFF. Exit programming any time by pressing clock button.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
That being said, if events conflict with each other, timer will not operate.
For example event1 ON FR at 7pm and event1 OFF all-days at 11pm.
The days have to match for on-off times.
Another example event1 ON FR at 7pm and event1 OFF FR 11pm, but event2 ON all days 8pm event2 OFF all days 10pm. This overlap will cause timer to skip programs.
If timer is being used in random mode, timer programs cannot be closer than 1/2 hour apart.
When programming is done, press clock button to display current time.
Timer should be ready to go.
Manual is fuzzy at this point, and does not specifically say, but it appears that you only press MODE button when you want to set another mode beside auto.
I e-mailed Intermatic last week about this unclear spot because several folks are writing in about this timer not going into correct MODE after programs are set.
MODE must be set to automatic
Press MODE button once for manual override function
Press MODE again and RDM displays for random >> this is for lights turning on randomly when on vacation.
Press MODE button third time, and AUTO shows on display >> you want timer in AUTO for timer programs to operate.
Here's the trick ... after setting MODE to auto, press clock button to display current time
If timer will not enter AUTO, then timer is defective.
If Intermatic sends response that is pertinent to your question, I will post again on this thread.
Add a comment any time, and I will respond.
Intermatic... | Answered on Dec 23, 2011
Open following links to identify timer and download manual:
http://waterheatertimer.org/Aube-T1032-timer.pdf
http://waterheatertimer.org/Aube-timers-and-manuals.html
Honeywell Aube T1032 is made for single-pole or 3-way applications, and works for all types of lighting up to 500Watts.
Timer has internal battery and cannot be exposed to freezing temperatures or extreme hot temperatures.
Intermatic... | Answered on Sep 28, 2011
Try removing battery, and then reprogram timer.
Some timers are reset when battery is removed.
Newer digital timers keep programs in memory when battery is removed, but in that case the instruction manual shows steps for resetting timer and deleting programs.
The HB88RC manual does not show steps for deleting programs or resetting timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#hb88
Intermatic... | Answered on Sep 21, 2011
Try removing AA battery from back of timer.
Question posted under HB88RC 6-button outdoor plug-in timer with battery compartment located on back of timer.
Instruction manual does not say how to reset timer.
Other newer timers are rest by removing battery.
HB88RC is replaced by newer HB8800 series with lifetime warranty.
If you have a different timer, then open following sources to identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Intermatic... | Answered on Aug 27, 2011
Open following links for timer manual and see lifetime replacement model for discontinued HB88RC
http://waterheatertimer.org/pdf/hb88rc.pdf
This timer is reset by removing battery.
If functionality is not restored with battery replacement, timer has gone bad. Try timer on different outlet, and with different Load. Test outlet with circuit analyzer.
You have nice website.
Intermatic... | Answered on Aug 04, 2011
Most digital timers suggest resetting as last-step effort to restore functionality.
This particular timer is reset by removing battery.
Try removing battery again. Otherwise it seems the timer has gone bad.
HB88RC is discontinued product.
Replacement is heavy-duty Intermatic HB800RCL 2-outlet or HB800RCH 1-outlet timer.
http://www.smarthome.com/25078/Intermatic-HB800RCL-Heavy-Duty-Digital-Appliance-Timer/p.aspx
http://www.smarthome.com/48715/Intermatic-HB800RCH-Outdoor-Digital-Timer/p.aspx
Less expensive and less reliable timer Woods 59403 with 1-outlet has quite a few 'timer won't work' questions on fixya.
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
Intermatic... | Answered on Jun 20, 2011
Amazon shows HB88RC is unavailable, exactly as you report:
http://www.amazon.com/Intermatic-HB88RC-Digital-Receptacle-Programmable/dp/B000W0VTLW
Replacement appears to be HB800RCL
http://www.amazon.com/gp/product/B001KBZUNK/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000W0VTLW&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0076WXDN34BZSM7YWBVH
Other outdoor timers have same buttons and functions: Woods 59403, GE 15117
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Intermatic... | Answered on Feb 20, 2011
First we need to identify the timer.
If you want to take a few moment and add a comment with a description of each button timer, and shape and purpose of timer, I might be able to identify the timer and will post instructions.
I have extensive files on timers.
Also look at timers on following pages to see if your timer shows:
http://waterheatertimer.org/UPM-timers-and-manuals.html
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
After identifying timer, add a comment and I'll post those instructions.
Most timers shown on pages above also have link to a manual
If you do not want to add a comment and identify your timer:
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Intermatic... | Answered on Dec 23, 2010
You posted under Intermatic HB88RC timer
If you have different timer, add a comment
HB88RC timer manual:
Here's HB88RC programming from the top:
Remove batrery from back of timer to reset timer and clear everything.
Re-install AA battery in timer so display will show, and you can program
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
If you want all week long, then press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 7pm shows >> this is event1 ON
Press Min button until :00 displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Match days with ON time: so press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 12pm displays >> this is event1 OFF
Press Min button until :00 displays for event1 OFF
When programming is finished, press clock button to display current time
When programming is finished, press MODE button to select MODE > you want AUTO for timer programs to operate
Press MODE button once and this is manual override, and lights come on.
Press MODE button again and RDM displays, this is for random timer operation
Press MODE button 3rd time, and timer is set to AUTO
After setting MODE to auto, press clock button to display current time.
Plug timer into receptacle.
Plug lights into timer.
Add a comment any time.
A lot of folks have written in about this timer going bad and they have been unable to program the timer. Of course most timers work perfectly fine.
Intermatic... | Answered on Dec 18, 2010
HB88RC programming Instructions:
Install AA battery in timer so display will show, and you can program
Set clock:
Program timer:
This is Event1 ON
Press Hour button until 5pm shows >> this is event1 ON
This is Event1 ON
Press Hour button until 7pm displays >> this is event1 OFF
Intermatic HB88RC - 7-Day Programmable Outdoor Timer - 15 Amps - 120 VAC Li Logo
40 questions posted
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Mike
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Intermatic Hardware & Accessories
Most Popular Question
hb88rc intermatic 7 day 7 event timer
  • Hardware & Accessories
