How to open ports 5198 and 5199
Access your router with username and password.
Then go to NAT and prot forwarding settings.
Select your port and open TCP and UDP protocol.
Then save settings and restart router.
***If you need any kind of technical assistance you can contact support cell at here
SOURCE: How do I open a range of ports on my VDI-604 or VDI-624 using firewall rules?
Step 1 You will need the IP address of the computer that you want to open ports to. How do I find the IP address of my computer? Step 2 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 3 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 4 Click the Advanced tab at the top and then click Firewall on the left. Step 5 Select Enabled and configure the following: Name - Enter a name to identify the rule Action - Select Allow Source Interface - Select WAN Source IP Range Start - Enter an IP address or * to allow this rule to apply to all incoming IP addresses. If you are opening this rule to a series of IP addresses, enter the first IP address in the range. Source IP Range End - If you are opening this rule to a series of IP addresses, enter the last IP address in the range. Destination Interface - Select LAN Destination IP Range Start - Enter the IP address that you obtained in Step 1 Protocol - Select the protocol (TCP, UDP, or Both) Port Range - Enter the starting and ending ports that you want to open Schedule - Select Always to apply this rule all the time or Schedule to specify a schedule Step 6 Click Apply and then click Continue to apply the new rule.
SOURCE: Port Forwarding for Allied Telesyn AR725
If you refer to this link, it should explain how to do it for you, best of luck http://alliedtelesis.custhelp.com/cgi-bin/alliedtelesis.cfg/php/enduser/std_alp.php?p_sid=psCY4LAi&p_lva=&p_li=&p_page=1&p_prod_lvl1=5&p_prod_lvl2=63&p_search_text=port&p_new_search=1&p_search_type=3&p_sort_by=dflt
SOURCE: open ports for echolink
Hello Paintah, The link below has a complete walkthrough of enabling these ports!
http://www.portforward.com/english/routers/port_forwarding/Westell/A90-327W15-06/Echolink.htm
Cheers!
SOURCE: I have a problem with echolink connecting via the Dlink 624
do port forwarding in that you get it in the modem or router any if the port forwading option is there or not
