Check out this WEB site for the full specs.
http://support.moonpoint.com/info/pc/motherboard/asus/P5PE-VM/specs.php
SOURCE: P5PE-VM asus board audio driver
Hello there.
Please click here to download the drivers for your audio chipset. You may note that Vista is not listed but the driver version for Windows XP works in Vista, there was a problem with the installer cd on Vista but apparently manually running the installer for the audio card, from the cd works fine. Click here to see what other users of the same motherboard said.
Hope this helps.
SOURCE: ethernet controller for asus p5pe vm
i have also a problem about ethernet controller, i can't access my internet connection !
SOURCE: asus p5pe-vm sound driver need
this is where the audio drivers are
you will have to type in some letters at the bottom of the page(just under the red stop sign) , and then click the download button next to it
http://www.driverstock.com/ASUS-P5PE-VM-driver-download/6-9-10170-81101/index.html
SOURCE: asus p5pe-vm series motherboard driver wont work with windows 7
Windows 7 is still in the beta/testing stage from what I remember.
If you go to this page courtesy of ASUS:
http://support.asus.com/download/download.aspx?SLanguage=en-us
In the search box type in your motherboard p5pe-vm and click on P5PE-VM related files for download
It will come up with a seperate window that will ask you the OS that your installing and windows 7 is not an option which tells me that drivers aren't available for your motherboard just yet, it may down the line once windows 7 becomes publicly available.
