Question about ASUS P5PE-VM Motherboard
What kind of driver will i use with my Windows xp ultimate that will be compatible with my motherboard Asus P5PE-VM
Posted by newjohn73 on
carlo de castro
    Sergeant:
  • 186 Answers
Hans Pedersen
  • ASUS Master
  • 3,606 Answers
Hello try to download the drivers here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
first select your current windows 32 or 64 bit
Select the driver and hit global for download
The file needs to be unziped before use
Good luck
Posted on Oct 31, 2012
I need all drivers for my computer. mother P5PE-VM, i need it quick plese.
http://www.getpcmemory.com/drivers/motherboards/download-asus-p5pe-vm-motherboard-windows-xp-drivers/
http://www.driverstock.com/ASUS-P5PE-VM-driver-download/6-9-10170/index.html
Regards.
Aug 21, 2010 | ASUS P5PE-VM Motherboard
A need drivers of p5kpl-vm/s motherboards for windows xp service pack 2 supportable
Hi, try these links for your drivers:
http://www.driverstock.com/ASUS-P5PE-VM-driver-download/6-9-10170-81103/index.html
Aug 20, 2010 | ASUS P5PE-VM Motherboard
P5PE-VM Motherboard: which vga driver is suitable for my asus p5pe-vm m...
1- hi
2 - check asus web site for compatible vga to your mainboard
3 - good luck
May 16, 2010 | ASUS P5PE-VM Motherboard
Asus p5pe-vm audio driver 4 windows 7
the audio for asus p5pe is soundmax ad1888 as of now there no driver that supports win7 you'll just have to wait until the product manufacturer releases a driver that will support win7
Nov 20, 2009 | ASUS P5PE-VM Motherboard
I Have Asus P5PE-VM motherboard and windows vista ultimate 32 bit installed on my pc. My SoundMAX Audio Driver didn't support this OS version plz help me
In this case if your sound max did not support your OS you need to Install the lower version of OS which is compatible to your soundmax driver, because higher version did not support the other driver,
Jun 30, 2009 | ASUS P5PE-VM Motherboard
I have installed vista ultimate but the drivers specially the sound card driver isn't working.. My motherboard is Asus P5PE-VM series.. Help me out
download driver utility from this link and install it, hope your problem will be solved.
http://www.lostmydrivers.com/driver/download/19336/ASUS/Mainboard-Drivers-and-Utilities-Drivers/ASUS-PC-PROBE-II-V1.04.68-WINDOWS-2000-XP-2003-VISTA-ALL-X32-X64-V1.04.68-WINDOWS-2000-XP-2003-VISTA-ALL-X32-X64-.
Jun 23, 2009 | ASUS P5PE-VM Motherboard
P5PE-VM asus board audio driver
Hello there.
Please click here to download the drivers for your audio chipset. You may note that Vista is not listed but the driver version for Windows XP works in Vista, there was a problem with the installer cd on Vista but apparently manually running the installer for the audio card, from the cd works fine. Click here to see what other users of the same motherboard said.
Hope this helps.
Apr 19, 2008 | ASUS P5PE-VM Motherboard
ASUS P5PE-VM Motherboard Logo
1,179 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Roy May
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
