Both toasters have blown in an identical area within two weeks of each other which leads me to beliefe that there is a fault in this particular model - CTO 4003.BK seriel no. 92517S900041
SOURCE: Toaster Does Not Work...
You may hve gotten some moisture inside the plug, just leave it for a few days to let it dry out, if the problem persists, send an e-mail to the following:
[email protected]
SOURCE: Light and oven does not turn on.
:-) Same here, in the middle of cooking the toaster just died. O' well, i am a tech! i opened the unit and diagnosed the problem. the unit has a non-resettable high limit thermostat that blows open when reaching high temperature. the problem is that when it happened, the oven wasn't even hot and was only on for a bout five (5) minutes. From my experience, it is due to a design defect. from all i have seen so far, it doesn't seem that the company cares about its reputation or customers... what can you expect from the French?!
SOURCE: Right side of the toaster will not heat up
At this point the problem is nit solved.
will look into a solution before investing any funds on the solution. There are many free options to be considered at this point.
Jackie
SOURCE: Delonghi AS690 toaster oven lower element won't turn on.
Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
