20 Most Recent DeLonghi CTO4003 4Slice Toaster Questions & Answers
I have no experience with the deLonghi toaster but in my experience automatic toaster all work in similar ways since they went electronic - toasters were about the first to do that. Pressing the lever down against the spring pressure also presses an internal switch that sends current to the heating element as well as to the electronics that control an electromagnet, the purpose of which is to keep the mechanism engaged until the toast is brown enough and then the current to the magnet will be cut by the browning brain and the toast pops up. If removing any crumbs from inside by inverting it and giving it a good shake and then pressing the lever a few times fairly vigorously doesn't make it work then nothing short of surgery will make it work so returning it will be the only realistic option.
DeLonghi CTO4003... • Answered on Aug 22, 2017
If by open you mean get the crumbs out, there are two slide trays. Pull them out rearward, dump them, and slide them back in.
DeLonghi CTO4003... • Answered on Jan 17, 2015
http://www.instructables.com/id/Poor-man-s-200-dollar-plastic-heat-strip-for-penni/step1/Materials-and-tools/
DeLonghi CTO4003... • Answered on Nov 07, 2014
Put duct tape over the slots on the side that isn't working.
JAMES WE ARE NOT ASSOCIATED WITH DeLonghi but I have owned a couple things they made and could never get them to assist me with a FIX so I do not buy their junk anymore
DeLonghi Kitchen... • Answered on Apr 23, 2021
Most self stopping kettles have a bi-metal piece, generally in the handle or top part, which, when boiling, gets one side of the metal to expand more than the other, causing it to bend and mechanically turn off the switch. There are many causes that it can stop working- iron fatigue, corrosion, jammed switch etc that can make it stop working. In general, it <strong>wouldn't</strong> be financially worthwhile to repair it, however many people still use them when they stay in the room, since they still do a decent job of boiling the water quickly. Typically they have a safety, so the thermo-fuse will shut it before a fire starts- on your own risk. It's usually not so expensive to get a new one, so I'd go for using it temporarily til I get around to getting a new one!
DeLonghi Kitchen... • Answered on Jul 01, 2019
DeLonghi CTO4003 4Slice Toaster Logo
15 questions posted
Top DeLonghi Kitchen Appliances - Others Experts
Paul Bade
Gerry Harvey
Gerry Harvey
ADMIN Canada
ADMIN Canada
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • DeLonghi Kitchen Appliances - Others
Most Popular Question
open delonghi cto4003 toaster
  • Kitchen Appliances - Others
