I would like to no how to fix it.
If it's a driver issue, HP/Compaq should have the drivers oon their site for your system, all you need to do is select which of the two models of theNX5000 you have, and get the drivers from HP, here's a link http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=395654
are you sure its yourusb drivers
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure
they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts if you dont have a motherboard disk you will need to download the drivers http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
hope this helps you
is it the driver that is not detected or the usb drives driver?
could see a yellow question mark?
fix the problem
click start control panel administrive tools ,computer
management ,device manager look through all of your devices if you see a yellow
question mark?or exclamation mark ! or red x
hope this helps
im not sure why you need a usb connection or port to get your computer working however you can plug your usb drive into any usb ports if you do this and your uab drive is not working
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
if all of this fails to fix your problem your computer back to the place you had it serviced and complain or ask for a refund
im sure they will fix the problem they have caused
hope this helps
fix the problem
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Available in this
download are drivers for VIA USB 2.0 host controller on a system running on
Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows
2000/XP are not available for download. They are supplied on CD with new
mainboards or available through Windows Update. This version is a bug-fixing
release.
hope this helps
