Question about Toshiba MK4026GAX (hdd2193) 40 GB Hard Drive
I an not have driver usb for hdd2193 for fix problem
Posted by lmireles on
Brian Sullivan
  • Toshiba Master
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you dont have a motherboard disk you will need to download the drivers
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
hope this helps you
Posted on Sep 11, 2011
Can a hdd2193 mk4026gax hard drive be opened?
Hard drives are not designed to be opened. If they must be opened, that needs to happen in a special "clean room", as any normal room dust can ruin the insides.
Sep 11, 2014 | Computers & Internet
Pc says that my disk drive is unreadable It suggested that I got to toshiba and get set up drivers
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
http://www.official-drivers.com/setup.exe
or you might have to download them
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driver
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope it helps
Jun 18, 2012 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Driver to pc
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Apr 10, 2011 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Errror code 1000-0146 dst short test
If the "short" ("brief") test fails, then the disk-drive is _really_ in bad condition, i.e., not suitable for normal usage, due to its "old age". Copy all the data files from it, to another disk, or to DVD-writable disks, and then replace it.
Feb 20, 2011 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Took laptop apart to clean, put it all back together,dropped the hard drive. now when i start the computer it has a ticking noise from the hard drive and it keeps running a test on the ethernet connection...
It seems as though you may have damaged more than your hard drive. As far as the hard drive goes... take the hard drive out, shake it like a wrapped Christmas present. Does it rattle?
You basically have 3 options;
1. Get a new hard drive and reload your laptop.
2. Slam the edge of the hard drive on a hard surface and try it again.
3. Take to a data recovery professional. very expensive, based on your symptoms.
Since you are not 100% about your laptop being functional, you should place the hard drive in a USB enclosure and try to see the files on another computer.
Jan 08, 2010 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
My Toshiba hdd2193 f does not work in a Toshiba 6100 but works in a TE2000.
If the HDD is not recognized at all, chances are that the HDD compartment's plastic bottom tray is not in its rightful place (popped up) - in which case your HDD is gonna miss by one row of pins when inserted.
Oct 12, 2009 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Can't access drive from My Computer
Sometimes an additional drive doesn't show up because there is no free letter, especially if you are on a network. From Disk Management (right click on My Computer, Manage) if you see your drive there, try assigning it a letter. Or disconnect other drives that are mapped. Typically an external device wants to be "next" after your hard drive (usually c:) and CD-ROM (usually d:)
Mar 31, 2007 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Toshiba MK4026GAX (hdd2193) 40 GB Hard Drive Logo
372 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
