My old dvd player allow me to set the d.comp setting for off which allow far more powerful lifelike sounds...i would like to resolve the issue quickly
SOURCE: on standby
Mine does the same thing..........
If anybody knows the problem ........please e-mail me.
[email protected]
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
SOURCE: Powers on 5 sec then powers off
There is a bad resistor that causes the unit to go into standby. For once, I actually bought an extended warranty from Sears who wound up taking the unit back FOUR times to replace the faulty resistor. The last time, I actually researched the problem myself and informed the repair shop that they need to upgrade the component to a higher voltage component - this actually fixed the problem for longer, but not much longer. I would trash it.
SOURCE: set up
You don't need to fake it with a VCR - on the back left side near the bottom there is a Monitor section with an RCA connection and an S-Video connection. Connect one of these to an input connection on your tv and switch your tv to show that input. Select the AMP setting of your remote and press Setup.
