Would like to restore back to factory settings, but need help on how to do it.
This WEB site shows how to do a factory restore.
http://www.tomshardware.com/forum/13678-63-restore-acer-aspire-factory-settings
SOURCE: restoring factory setting
Its not clear that which setting you want to reload.
1. if you mean to load BIOS then go to setup. There will be an option in your BIOS setup 'Load Default' , use this option to re-load your BIOS settin as per company settings.
Note: To enter your BIOS Setup,
Power On your system, and press 'Del' in some setup it require 'Esc' or 'F12' or 'Tab' key, so see on the screen it will display when you power on.
2. If you want to reload your OS as it was shiped by company. then you have to use 'Recovery CD'. this will be shiped with your PC, check out and boot from that CD and follow the on screen instructions. it will recover the original settings and software.
Thanks
Iqbal
SOURCE: need to restore acer to factory settings
contact acer you can get there number from the website and they will let you purchase a restore disc for 15bucks
SOURCE: how do i restore my dell back to factory settings
If you mean BIOS setting, then enter the BIOS, choose Restore Defaults.
If you mean your windows installation, use the Operating System reinstallation CD from DELL (the green CD, for Windows XP). After operating system installed, use your driver CD (usually the blue CD from DELL). If you don't have the CD, please contact Dell support center to get the CD (charges may apply).
SOURCE: I have a Acer Aspire L100 and would like to
If you have lost the automatic restore then you need recovery CD to restore it. To download try this link:
http://www.user-guides.co.uk/cddownload/Acer/AcerAspire/Acer-Aspire-L100-XP-Driver-CD-Recovery-Restore-Disk-115940.html
SOURCE: acer m1640 factory restore
Format the drive, then install an operating system such as xp, or windows 7 .... it should install most of the correct drivers. You may have to go to the manufactures website to find the exact drivers for the video and sound cards., but that should pretty much return it to factory settings. If you are really picky and have the bucks, you can contact ACER for the original disks.
Acer are cheap and they don't provide you with a factory restore disk. You need to make this factory disk yourself. I know how to do this, but it is to much for me to type and here is a really really good reference site for you to visit to get instruction to make your own factory restore disk. After making that restore disc, pop the disk into your laptop and turn of your laptop and restart and the factory restore program should start, if it should not start then go into your bios menu and have it boot from your Dvd-Rom and save, after full restoration, make sure you turn your boot priority back to where your Os is being installed, exm hard drive.
http://www.ehow.com/how_4478845_restore-acer-computer-factory-settings.html
