It is tricky to repair the space bar. It has a plunger in the middle and is held in place by tension clips. The tension clips are what make the spacebar pop back up. Usually one clip comes loose and the other side still bounces. If the spacebar is stuck down with no bounce, I would check to see if there is something wedged under the spacebar. Get a can of compress air and blow under it, hopefully this will release whatever is under there. Only take the spacebar off carefully without jerking it upwards. If it breaks the clip holder at each end, you will need a new KB.
Good Luck.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
