Step 1:
Since entering the marketplace and revolutionizing the way people experienced personal audio, Apple's iPod has become the unquestioned leader in MP3 players. Available in several different models and versions including the original iPod, iPhone, iPod Nano and iPod Touch the iPod allows people to listen to any number of songs with just the click of the button. However, as is the case with numerous electronics, certain iPod users encounter issues with their device, particularly sound issues. These issues range from buzzing sounds through the headphones to low volume quality to no sound at all. Fortunately, there are ways to attempt to remedy these sound issues.
Volume and Song Selection Oftentimes, those iPod users listening to heavier music (such as rock or hip-hop) will encounter a buzzing noise when playing their device at maximum or near-maximum volume. Try lowering the volume a bit, as this will most likely remedy your buzzing issues. Also, try playing a different song from a different artist at the same volume to ensure sound quality is optimal across the board. Check the Headphones Before attempting to diagnose an iPod's sound issues, ensure the iPod itself (and not the headphones) are the culprit for these sound issues. Do so by disconnecting headphones from the iPod and playing them on another device, such as another iPod, a PC or laptop. If the quality is still not optimal, the headphones (not the iPod) are likely the reason for low sound quality. Also try connecting an iPod to an iPod listening dock. If the sound quality is optimal, but not so when connected to headphones, that would also indicate headphones as the cause of low sound quality. b> Reset the iPod Sometimes, simply resetting an electronic device such as an iPod, digital cable box or video game system will remedy the solution, as it gives the device a chance to reboot. Try resetting the iPod to remedy whatever sound problem you may be encountering, whether it's no sound or less-than-optimal sound. Not all iPods are reset the same way, so consult the user manual (either paper form or through Apple.com support) to learn how to reset a particular type of iPod. Adjust Sound Settings If sound quality is less than optimal, including too much bass, not enough bass, poor acoustics or any number of other issues, try altering an iPod's system settings to correct the issue. Do so by going to the "Settings" key on the main iPod menu, then going to "EQ." From there, test certain settings to see if they may correct the iPod's issue. EQ settings allow users to set their music to a certain type of genre (in terms of how the music is delivered), as well as lowering bass, increasing bass and altering acoustics. b> Make Sure Headphones Are Fully Connected As simple as it sounds, sometimes the reason iPods have no sound at all is because their headphones become somewhat detached from the device. Such is the case with physical activities such as exercising or doing yard work. If no sound comes through the iPod, make sure the headphones are plugged in all the way to ensure the lack of sound is not a simple oversight. Consult Apple Support Whatever the sound issue, if iPod users have tried everything possible to remedy the problem with no results, they can call Apple support or visit an Apple retailer to help further diagnose the issue. The issue could be a simple fix or might be so severe that purchasing a new iPod is the best course to travel.
SOURCE: apple ipod nano wont play the full song
First make sure your hold switch isn't on. It's on the top or bottom and slides
back and forth. It needs to be switched to the left. Once it is to the
left, here's how you reset:
You can reset your ipod by holding down the menu and select (round
button in the center) buttons down for at least 10 seconds. You'll see
an apple logo flash, that's when you stop pressing the buttons. It will
shut off, then back on.
SOURCE: how to download songs Mp3 format onto ipod nano 8GB model A1236
Hi! Congrats for your ipod nano. Use latest version of iTunes available on http://www.apple.com/itunes/download/. Install it and then connect your ipod with the pc. Hope this solves your concern.
SOURCE: Deleting songs from Ipod Nano 8GB
When you connect the ipod nano to the computer, you can do one of two things: you can go to the ipod's main home page in itunes and go to the bottom where it will have four options listed. 1 of them should say manually manage files. Click on the check box next to it and it should ask you if you are sure and click yes. Then go into your music folder of your ipod and delete the songs you don't want on there. To add music, all you have to do is click and drag what you want onto the oped. The second way you could do it is to go into your library before connecting your nano to your computer and un-checking all of the boxes next to the music you do not want on your nano and then connect it to a computer and let it sync. The first way is easiest and less time consuming as you only have to do it once. Hope this helps!
SOURCE: adding and deleting songs from my ipod nano 4th generation
2 guides that would help you :-
http://www.everymac.com/systems/apple/consumer_electronics/ipod_faq/what-is-ipod-how-to-turn-off-delete-photos.html
http://ipod.about.com/od/addinganddeletingsongs/Adding_and_Deleting_Songs_from_your_iPod.htm
Thanks.
SOURCE: How to save songs from my nano (the old ipod nano)
I used TouchCopy for this, it's the best <a href="http://www.wideanglesoftware.com/touchcopy"> iPod transfer</a> software out there. It copied all my iPod songs, videos, playlists and photos to my to my new computer.
